The Best lug nuts and studs money can buy, inside
Supporting Vendor
Here at GSpeed, we were dissatisfied with the options that were available for lug nuts and the typical ARP stud. They worked, and got the job done, but always left something to be desired.
These studs are bad to the bone, no other way about it:
- 20mm starter cone; reduces chances of cross thread.
- Heat treated for ultimate strength
- Dry film is baked on, and stays on for years of service. No anti-seize needed. (Note: Heavy track usage may warrant more frequent replacement.)
- Long enough for spacers and thicker wheel pads, yet short enough to save weight.
You may use your current lugnuts, or opt for ours.
- Lugnuts come painted yellow, so you can see them, or chase them
- Baked on moly coating never needs lubricant.
- Low clearance for tight clearances on some wheels
- 19mm socket
We will update the site so the lugnuts and studs can be purchased individually, they are currently in kit for, studs and lugnuts.
If you purchase a set of SKFs and studs from us, we will install them free of charge.
https://gspeed.com/product/vette-ext...tuds-lug-nuts/
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
BigMonkey73 (06-28-2016)
Any chance you could share a picture of how the tail wing arms in your web site are mounted to the chassis?
Any pictures with the rear facia plastic off?
Do you guys have the swan neck versions?
Its not a swan neck, and uses the known quanitiy GT2 wing from LG motorsports.
If youre considering purchasing one, I can explain in private how we mount the wing. I ask those that have purchased this kit not to share, as the imitators just come out of the wood work.
Fair enough, I figured that since there was no response. I was actually trying to get ideas, since I'm trying to rig up something that'd dual purpose as tire trailer hitch as well as mounting point for a wing. I'm also thinking of possibly fabricating swan neck brackets.
Supporting Vendor
That being said, we'd love to fabricate something custom for you.
Jake
Seeing those bolts coming out for mount point, I figured it wouldn't work for a small hitch, but I was just curious and trying to get ideas in order to get my act together!
I'm even thinking of coming up with a double exhaust tip to open up room for the chassis for mounting point. Or even a Ferarri style triple tip..something many members here would love to crucify me for!
GSpeed (07-01-2016)
I appreciate it. I have a CNC programmer friend who has volunteered to help out, once I come up with a concussion. As much as I'd love to, it'd easier on my wallet!
We ran some FEA numbers for the wing itself, and it could probably support a small tire trailer, with say 50-75lbs of tongue weight, but with out figuring out exactly the load rolling down the highway, its hard to say.
http://m.harborfreight.com/500-lb-ca...not%20provided
I'm trying to come up with a bracket, attaching at two point to the chassis, with a center 2" tongue to support this. Then at the two chassis attachment points would each have a gusset to attach each of the wing brackets. It'll most likely be a while before I am able to think through a clean design, where I don't get egged on the street by Corvette enthusiasts!
Sorry for the thread/jacking, hopefully GSpeed doesn't mind all the free bumps!
