Temperature disc paint kit
Old 06-29-2016, 09:11 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default Temperature disc paint kit
BREMBO TEMPERATURE DISC PAINT KIT
Brake disc paint is for people who regularly track their vehicles (typically used in racing) or have vehicles that are hard on brakes in which it's a good idea to keep brake disc temperatures in check.
Aside from a pyrometer, thermometer, or infrared sensors, Brembo Racing rotor paints are the most cost-effective solution to managing brake disc temperatures.
Green: 430C/806F
Orange: 560C/1040F
Red: 610C/1130F
Once they reach the specified temp range, they oxidize which turns them green/red: white or an orange/off-white (yellowish tint). If they reach the peak temperature.
Tech tip: disc paint should be painted liberally onto the entire width of the disc including vane and rotor cheeks.
http://www.xplosiveperformance.com/B...IT_p_4117.html
BREMBO TEMPERATURE STICKERS
Utilized in motorsports/racing, these stickers help you to monitor your brake caliper temperatures (ranges from 350c to 450c).
Sold in pairs or packs of ten.
http://www.xplosiveperformance.com/B...RS_p_4118.html
Old 07-28-2016, 08:34 AM
Former Vendor
St. Jude Donor '13
Old 07-28-2016, 10:06 AM
rfn026
rfn026's Avatar
If you run on the track you need to know your temperatures.
Brake Temperatures 101
Richard Newton
Old 08-11-2016, 08:37 AM
Former Vendor
St. Jude Donor '13
Old 08-24-2016, 08:09 AM
Former Vendor
St. Jude Donor '13
To Temperature disc paint kit
Quick Reply: Temperature disc paint kit
