Best hot pressure for Michelin Sport Cup 2
I have a C5Z with 10.5" rims in a square set up and Michelin Pilot Sport Cup 2s 295/30-18s. Running neg 2.5 camber up front and neg 1.5 in back. (still on stock rubber bushings so have no idea of what the actual dynamic camber is). Only mod is a front Strano sway bar. I do not have a pyrometer but tire wear seems really even i.e I am very pleased with it.
Question is, what is the best hot pressure? I have heard from 32 to 36 PSI. ( I usually aim for a 6-7 PSI increase from cold and assume I lose at least 1 lb during a cool down lap). Would love to hear your experience.
mxk (07-21-2016)
Thanks, I had seen this and I suppose the Sport Cup 2 is likely pretty similar to the Sport Cup although I think the compounds and sidewalls are different.
At my last competition event, part way through I tried raising my pressures to what I think would be 36 PSI from 32-33 but I ended up going a bit slower.
Interesting that according to the article quoted, an increase of 100 degrees F should turn out to be about 7 PSI which seems about right.
