How to set the rake corractly on a sports car? Not much testing time available.
My car handles great, I am installing some slightly shorter front tires and to keep the rake the same I thought I would raise the front of the car to offset the new smaller radius tires.
But then it occurred to me, is there a certain ideal rake, height, or some other measurement that I am not taking in to account? Maybe suspension geometry considerations?
I will not have any appreciable testing time as I only get to the track 1-3x/ year and I work insane hours, so I need to make the best decision, in the garage ahead of time.
Can anyone give me some guidance on this issue? Currently the car is pretty slammed btw.
Thanks!
Thanks!
Location: If you don't weigh in you don't wrestle Road America
Get yourself a trim height tool - this measures A-arm angle to let you know that your suspension is set-up properly.
I believe the J-tool number is J-42854 around $100 on Ebay.
Received 8,919 Likes
What is the difference in diameter of the tires? Make sure you are only looking at half that measurement since that is all the ride height changes. If you are talking a half inch or less I wouldn't worry about it.
Bill
Bill
11mm radius difference. Honestly some of the issue is the darn car is so low currently.
Trim height tool huh? I don't know what that is but I will look in to it.
Please advise.
Check out post #32 in the thread linked below:
https://www.corvetteforum.com/forums...pension-2.html
There are trim height specs in the service manual and I believe Pfadt had/has some specs as well.
I agree, that's what I have decided to do. I figure it can only improve my suspension anyways.
https://www.corvetteforum.com/forums/autocrossing-and-roadracing/2681396-ride-height-how-low-possible-on-stock-suspension-2.html
My left/right rear are off more than 1/2" when ride heights are set at the arms.
Don't worry about the rake. It is more important to set the ride height and the cross weight to 50%. In order to have a good handling car the cross weight needs to be 50%. If the car looks lopsided, don't worry about the static attitude if the cross is 50%. When you put the car on the scales, make sure the scale pads are bubble or laser level, the tire pressures are set, the running fuel level is in the tank, driver's weight is appropriately set in the driver's seat, the swaybar(s) is/are disconnected, check and recheck by joucing the car when any adjustment is made. Then you drive the car around the block and put the car back on the scales and adjust to 50% cross.
Unless you add some weight to the car, good luck in trying to get the driver's side percentage better than 51%. You may get lucky in getting the front to rear 49/51 or even a little closer to 50/50. Don't sacrifice the cross for the front/rear or the side to side.
I hope this helps.
I hope this helps.
It does. My car is corner balanced and that's one of the things I'm concerned I'll mess up.
Does altering the rake, move the A-Arms and therefore effect your camber?
See attached pdf page 5.
http://www.pfadtracing.com/pdfs/Feat...2003.20.13.pdf
I find measuring with the J-tool is best for me - YMMV
