Height Adjuster Locking
I'm going to adjust my car back up to the stock ride height (6" front, 6.22 rear). The car had self-adjusted itself down to 4.5".
I read a thread where people were adding a fender washer and nut on top of the front spring. Is there some reason GM didn't put a nut on it from the factory?
Does anyone have concerns with:
- damaging the top of the spring from the washer pressure (maybe put some rubber under it)
- is the spring perpendicular to the bolt at that location or at an angle (potentially increasing the risk of damage from the nut / washer)
- does the spring need to float and potentially shift left / right at the ends as the spring deflects during suspension travel (I don't remember how large the clearance hole is around the adjuster)
.... or is adding the nut / washer something that is frequently done without concern?
Rob
Rob
Never heard of a nord lock. They look interesting.
Going from the underside is probably the correct way to do it. How hard is it to remove the adjusting screw?
I know this was covered in one of the many posts I read but I didn't write it down and can't find it again.
Whats the relationship between turns of the adjusting screw to change in height?
I use aftermarket ones that go from the top so its really quick since I can just back the bolt out without disconnecting everything
with the oem ones it needs to come out from the bottom.
disconnect the sway bar end link from the lower control arm
disconnect the tie rod end
disconnect the lower shock mount
disconnect the upper ball joint
then you can remove the oem spring adjuster
note: you will want to have a jack handy to support the lower a-arm while disconnecting everything
good luck!
good luck!
