LG Motorsports Solid Engine and Trans Mounts
Old 10-06-2016, 05:44 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default LG Motorsports Solid Engine and Trans Mounts
-RELEASE-
I should say re-release as we have had solid engine and transmission mounts for years now used in all of our race and track cars but we have recently made changes to them to make them lighter than the original designs.
Our billet aluminum C5/6 engine mounts are designed as a direct bolt in replacement for the OEM piece and have all required hardware supplied. They are slightly lower to add additional clearance for FAST intake manifolds.
MSRP $169.95
LG Motorsports C5/6 Solid Engine mounts
Our lightweight billet trans and diff mounts for the C6 are taken directly from our GrandAm race car from a few years back. Solid billet is machined and finished for the most strength while removing as much weight as possible. Studs are supplied so install is just like replacing the OEM piece.
MSRP $269.95
LG Motorsports C6 Solid Trans / Diff Mount
Old 12-06-2016, 01:56 PM
Former Vendor
Back in stock!
Quick Reply: LG Motorsports Solid Engine and Trans Mounts
