C6Z control arms = any c5/c5z control arms?
froggy47 (10-27-2016)
Obviously the rear LCAs are different on C5 vs C6.
Same for rear upper control ares for C6Z and C5 (and steel frame C6).
Would be curious to know if anyone has info re C6 steel frame rear upper vs C5 and front UCA and LCA vs C5.
Here is what I have found so far
Front Upper control arms are interchangeable between C5 and C6 (also considerable cheaper)
Uprights are interchangeable between C5 and C6 (09 and later C6 uprights are much stronger than earlier ones)
I BELIEVE front lower control arms are interchangeable
froggy47 (11-01-2016)
I wonder if the rear upper C6z control arms will work on a steel frame car if you dont use the dogbones - ie if you remove the oem bushings and use an aftermarket bushings kit for a steel frame car...
