C6 Z06 aero lift ?
Bigger ***** Seriously, I don't doubt that the C6 Z06 can go flat through the kink - better drivers than I do it and I'm sure they're going faster. I just never felt comfortable doing it in the C6Z. That's really the thing for me in the C7Z is that it's confidence inspiring.
To me, non pro, 5-6 events a year, the difference between 130 and 140+ through the kink is significant. I think it is definitely ball size, and risk comfort level. All influenced by car handling and feedback. I just checked 3 of my top 4 laps at VIR this past fall with the new aero described in above thread. I'm entering the kink about 140 and exiting about 150. last year without the aero and suspension changes, I was happy/comfortable with 130. I don't think that is foot flat. I rarely drive with my foot to the floor as far as I know. I haven't conquered the 2:00 barrier but I'm closing in, added aero is a huge part of this undertaking with the C6Z06.
Last edited by 1badtantrum; 11-30-2016 at 03:31 PM. Reason: video link remove (no hi-jack)
I've had my car >175mph at 1/2 mile events and it wasn't a huge deal but the lower my car is the better it feels, and just did trackspec hood vents which also made a noticable improvement in front end stability at speed while also helping air flow and cooling.
St. Jude Donor '11, '14
I hope you guys that are lowering your cars are using rake and scales when you do it. I put my weight in salt in the drivers seat plus typical amount of gas and heated tire pressure. I also use frame height for rake not fender tops.
Grand Sport
I have had my bone stock 2012 GS coupe to 175 on a straight followed by a flat but large radius corner at 140. No lightness in either the straight or corner.
I think that a lot of the problems arise when the owners place larger rear spoilers on which causes more rear down force with no down force added to the front. I think Pfadt Racing Engineering had a chart one time on the C6 showing down forces and explaining the problems with added spoiler.
Just my experience.
Just my experience.
c5racr1,
Those images say alot! Lots of downforce from that big wing, way out of balance with the front aero. Next image looks much more balanced.
700 front, 750 rear?
plywood splitter fiberglass wrapped?
How do you keep the plywood sealed to the bottom of the front fascia?
Radiator tiltied forward?
700 front 750 rear, oak plywood splitter, painted with a marine water proof paint. The plywood is sealed via a number of turn buckles mounted to various parts of the frame in the front, sling with the 2 splitter supports. In the rear it has some big zip ties at the pick up points where the stock leaf springs mounted. The radiator is in the stock position, have not leaned it forward yet. No cooling problems, but I run NASA time trials so at most 15 minute sessions.
#34
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just my experience.
Just my experience.
#35
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
On my 2007 Z06 I have a ZR1 style front splitter and just recently installed a splitter brace. ZR1 side skirts as well. Is this sufficient frontal down force to offset the down force created by a rear ring? Or will I be unbalanced? Have been considering an APR wing. Car is tracked.
#36
taking off the airdams under the nose will eliminate the pressure under the nose. They say those are for street economy, but they just create high pressure where you don't want it.
Mordeth (12-11-2016)
#39
That first pic, are you in 3rd gear? If so, 550whp in 3rd gear on slicks would tend to squat the rear.
#40
Wing
If you look at my top picture, I had the exact setup you are going to. The rear wing set at zero angle of attack was too much for the apr stuff, I have side skirts also.
Mordeth (12-12-2016)
