rear camber adjustment with Pfadt camber kit
I have acquired my first Corvette, 2001 Z06. I will use it primarily for HPDE.
It has the Pfadt camber kit on it but the rear is set to -1.9. I would like to change it to -1 to -1.1. I don't see that aFe Pfadt sells shim replacement packs and I got nothing with the car.
The front is -1.5 / -1.6 so I'm good there but I could use some shims for the front as well. Those look a bit simpler, i think I could make those if I had to.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
On the steel frame cars the only way to adjust rear camber is via the lower camber plates. The afe pfadt kits should have come with extras. use the plates that will bring the lower arms further inboard and then recheck the alignment. I have attached their installation guide which outlines the process.
Supporting Vendor
You could also upgrade to the AMT Motorsport camber kit which allows adjustment in the rear without having to swap plates in and out. We will be selling kits for the rear-only for just this purpose.
I hate that you have to keep track of a stack of different plates - on a couple of occasions Ive had the aligner try and keep the extra stuff as if I wouldnt notice...
As far as the the lower adjustment plates go, you could contact pfadt directly.
Alot of the replacement parts they sell arent on their site, but theyre usually willing to try and help out their customers.
Otherwise if youre stuck having to get a whole new pfadt kit, the AMT ones look like a great option at a significantly lower price with more features.
As far as the upper shims go, they are are generic - you can get them for cheap from mcmaster carr
I tried to get a hold of the replacement plates and was totally unsuccessful. Let me know if you're able to get further.
I've call afe/Pfadt and also emailed them. No response yet. I'm not easily dissuaded, I've been selling for 32 years. I'll keep on them. I can't believe this is not a common issue. I have a bunch of stuff still to do on my car. I'd hate to have to go away from afe/Pfadt because they don't support the products the already have in the field.
I have heard back from AFE / Pfadt regarding the C5 rear camber spacers. Pfadt will sell a full set of rear camber spacers for $150
Instruction on how to do so below:
If you are interested in purchasing this kit please follow the following instructions -
You will need to go on to the aFe CONTROL website (following the link provided below) and order qty 15 of the following Miscellaneous charge
http://store.afecontrol.com/misc-service-charge/
In the notes, please enter part # 00P-0A1068-A
My question is do I NEED a camber kit in the rear to achieve -1.1?
Thanks for any input
Bossdog -- what plate is in the rear now? How many notches? You may be able to flip it and get the range of camber you are looking for.
Going back to stock will give you the camber you want but then you'll have the possible movement of the eccentric if not torqued very tight.
I had better luck going in the " sales door" rather than the " service ". I spoke with Marvin in sales and he got me an answer. Service did eventually reply with the same answer but it took a while.
What is the price of the rear only kit. What is the degree change between each of the 10 setting?
Bobby
Bobby
Supporting Vendor
I've said elsewhere and I'll say it here again - if you're someone who wants to see your camber settings identical on each side of the car then this probably isn't the kit for you. There is more rear adjustment available than anything else on the market but it's not perfect adjustment.
