A run of really bad luck
#61
For the OP...if you don't mind sharing...about how many hours / track days / sessions would you say before your initial issues with the crate motor ?
Also, what oil / water temps would you normally see ?
ALso, conservative tune, or were you pushing the AFR ?
Got more than a few folks running the LS3 crate motors locally...no problems so far but some have reported persistent high water temps.
Now even when I was comfortable in the car, I was still fairly easy on the engine. I generally shift in the 5-5800 RPM range. Only at the Glen did I rev the engine to 6-6200 RPM.
This was Arron Pfadt's race car and test mule for his products. It was designed to run in the desert outside of Salt Lake City. Before the Road Atlanta crash, the front end was pretty much OEM except for twin oil coolers behind the fog light openings that vented into the wheel wells and a large custom splitter. Water temps never exceeded 210*F and oil temps never exceeded 240 even running Road Atlanta in July and August.
The rebuild after the crash was done with a Black Dog Racing fascia and splitter with a custom air box to route air to the radiator. That part totally failed at the Pitt Race track just due to the roughness of the track. That caused the water temps to increase dramatically and I had a number of instances where the water temps were over 240*F.
The engine was tuned by ZIP and was a fairly conservative tune.
I think the LS376/525 is a great engine. I believe it has a problem with the valve springs getting weak and allowing the valves to float. That possibly allowed the lifter to rotate ad wipe the cam. Valve float can also allow the valves to impact the pistons and that may have been why the piston failed.
Just my 2 cents.
Jim
