HPDE Tires
HPDE Tires
Picking up a 2nd C5Z just to use for HPDE's and set up as a track oriented car. I've been looking at tires and discovered there isn't much available these days in stock sizes for regular street/track. I've been using only RComps for many years on my current C5Z.
I was hoping to run Re11's, but it look like I would have to go down a size (255/17 and 285/18) for the OEM wheels. No sizes available in RE71R. I get a killer discount on BS tires, so they are my preference. Also looked into RS3's and no sizes there either.
What are you guys running on the track in the 200 treadwear category?
Has anyone put the 255/17 and 285/18 RE11's on the OEM wheels? How is the fitment? I see it technically works according to BS, as 10.5 is the largest wheel for the 285's, but I'm very particular about things fitting properly. Anyone have photos of that setup on OEM wheels?
Thanks!
Thanks!
Thanks!
Thanks!
I have pictures of a 285 RE71R on a TSW Nurburgring 18x10.5 rim. They're below:
I was looking at TireRack. Looked again and yeah...definitely missed. Apparently didn't have enough coffee this morning.
They look like they fit just fine. Tiny bit of stretch, but good to go. So I have the option of using the RE11 or 71R. Great! I've been using the 71R's on my current track car (BRZ), but have no experience with them on a C5Z. What are your thoughts so far? How many track days are you getting out of them?
Feff
It is obviously a great autocross tire as well. Just not sure it is good for HPDE.
Received 8,928 Likes
Get some 17x11 rims and run 315/17s at all 4 corners. Car will be fantastic on the track. I used to run the Kumho 710s in those sizes. I was able to rotate tires and got great wear out of a set of tires.
Bill
Bill
Unless you're running Hoosiers there are pretty much zero tire options in 315/17 anymore. You'll want to run 18" wheels to get decent wider tire options.
If you have a dedicated track car and trailer it why not just get slicks?
Slicks will make you fee like Superman. At least for a while.
Richard Newton
Tools for Your Tires
Richard Newton
I've been tracking a BRZ for the past 3 years and that's what I learned on. I've gotten pretty good at making a slow car fast, and am very smooth, but don't have my head in the clouds when it comes to thrashing a ZO6 on the track.
It's not a dedicated track car and it won't be trailered. I'm just looking to put some nice 200 treadwear tires on the thing to get some track time and some experience with that car under my belt. Not terribly interested in trying to dominate the field on a set of slicks my first time out at an HPDE. Surely some of you experienced folks can understand that.
I get a great deal on BS tires, so when I find that 2nd Z for the track, I'll likely be running RE-11's for a while.
St. Jude Donor '15
Perhaps the Michelin PSS would be the better investment with the higher up front cost?
If you're fast and it's hot out the MPSS will likely chunk at full tread (just like a lot of street tires). I thought there was a new one coming though?
Like others have said the RE71R's don't last. I nearly used up a set of 285/30-18 RE71R's in a single day at the LS Fest.
I'm liking nitto nt-01's on my car. I have 315/30/18's for front and rear. I've only run them at two events so far but they performed well. They are 100TW and I'm not sure about options for the stock front wheel. They are also no Bueno in the rain.
There is a lot of information on this forum about tired. A quick search would land you a couple hours of reading and feedback.
I would look at Hankook RS3's and Bridgestone RE-11's before committing to the Pilot SuperSports.
BigMonkey73 (01-12-2017)
