Diff fitting size?
14mmx1.5
Use Fragola fittings for this and trans. Russell or Earls are too long and will bottom out unless you cut them. I also used an o-ring like GM uses instead of a crush washer.
-6 is Fragola 460614
Are the fittings the same for the left side and drain for diff?
Try to get parts ordered before I start tearing down
Thanks again
zrtman1
the diff drain is the lower/lowest connection in the diagram right?
That thread should be the same 14mmx1.5.
The diff fill port is the M20x1.5
I tried using a regular right angle ORB to AN fitting on the diff drain (lower hose connection) and the fitting contacted the rear subframe/diff mount. I had to go back to the stock clip fitting... I see Fragola has some banjo fittings or low profile R/A fittings. Don't see the M14x1.5 thread...
