Why Does the Corvette Racing Team Win so Much?
Old 02-15-2017, 02:00 PM
Corvette Forum Editor
CorvetteForum Editor
Corvette Forum Editor's Avatar
Default Why Does the Corvette Racing Team Win so Much?
Corvette racing success lies in continuing to "perfect" the front-engine platform, says Corvette Senior Engineering Manager, Chuck Houghton.
Read the rest on the Corvette Forum homepage. >>
snow (02-16-2017)
Old 02-15-2017, 05:54 PM
HoldHard
HoldHard's Avatar
Default So if Corvette Racing Wins so much, What happened at the Rolex 24?
Have been a Corvette Racing fan for more than 15 years, going back to the LeMans winning teams.
Chevrolet Racing has the best pit crew as was shown multiple times during the 2017 Rolex 24 at Daytona. They would come in 3rd or 4th and then leave pit row in 1st place. Then the Ford GT, the Porsche 911 RSR and the Ferrari 488 GTE would pass them on the high banked "speedway" portion of the track. The Corvette team can simply look at those cars and see the smaller frontal area, specifically on the Ford GT which leads to better aerodynamics.
Coming in 4th, not even on the podium, should be a wake up call for Chevrolet. Pratt and Miller had better get going on the C8.R mid-engine if General Motors wants to be competitive in the GTLM class. If that is going to arrive in 2019 then it's going to be another year of non-podium finishes for Corvette Racing.
HH
Old 02-15-2017, 09:13 PM
ringo11
ringo11's Avatar
But I wouldn't panic just yet, lots of strategies, engineering and racing ahead
The following 2 users liked this post by ringo11:
GFaulk (02-16-2017), snow (02-16-2017)
Old 02-16-2017, 07:06 AM
jonny5cam
jonny5cam's Avatar
HH
What do you mean "another year of non podium finishes"?For starters, they went 1 and 2 at Daytona last year and won the 12 hours of Sebring right after that.
snow (02-16-2017)
Old 02-16-2017, 07:22 AM
snow
Support Corvetteforum!
snow's Avatar
St. Jude Donor '10, '17-'18-'19
Different tracks different opportunities to win. Don't count Jake out for 2017
Old 02-16-2017, 08:29 AM
rocsvette
rocsvette's Avatar
Well we know they aren't winning because of favorable BOP, but others are. As to changing their platform, Corvette Racing is one of the driving forces in how the street car is done. For example, front breathing C6 was driven by CR needing a front breathing car to remain competitive. Likewise direct injection in the C7.
The bigger issue is the erratic enforcement of rules and you only have to look at the prototype being passed off as a street car - the Ford GT. They started with their prototype and reverse engineered a street car which has yet to be delivered more than a year after they were allowed to race. Ironically it was Ford complaints in 1965 that Ferrari hadn't built enough 250GTLM to homologate (and they built more than Ford has of GT) that kept Ferrari from entering as a homologated entry.
The secret to Corvette success is no secret; professionalism, attention to detail, the best pit crews and team members. I've been at tests and in the hot pits many many times and the team is a testimony to never giving up, ever.
jonny5cam (02-16-2017)
Old 02-16-2017, 10:10 AM
jonny5cam
jonny5cam's Avatar
Camp is a 50' X 50' chunk on the Ullman straight this year at Sebring. Cant wait cheer on the C7rs and the Cadillacs. Great time!
Old 02-16-2017, 12:07 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes on 715 Posts
Originally Posted by rocsvette
..............Well we know they aren't winning because of favorable BOP, but others are. .............
What Roc said!
Old 02-16-2017, 12:44 PM
z28lt1
z28lt1's Avatar
Received 1,967 Likes on 1,029 Posts
HH
The forum had similar posts after the Rolex 24 (mostly in the C7 forum) so I'll repeat some of what I said on those threads.
First, I agree that the Corvette "team" including the Pitt crew is outstanding, and probably the best there is.
That said, being a good team, unfortunately, was not the reason the pit stops were that much quicker. The series regulates fuel flow in an effort for all teams to be able to fill up the tank the same speed (they also regulate tank size and it varies as the balance the other performance) with the goal that the each team can go roughly the same laps at top performance and takes the same time to refuel.
In IMSA, you can fuel at the same time as the other work. All the pro teams can get their normal pit work (change tires, driver change, tear-off on window) in the time it takes to fuel, so what the Corvette team had going for it was fueling faster, which will be balanced in the next races and that advantage will go away. Note that at Le Mans, fueling occurs separately from the other work, being quick at the other items pays off some, unlike in IMSA (unless you can't get all the work down during fueling).
Likewise, as the cars performance are balanced, there is no reason to state that the Corvette team will struggle this year for any reason. Corvette won the team, drivers, endurance and manufacturers championship last year against the very same competition. The Corvette (like every car in the class) can go faster than the series allows if left "open". The problem we are seeing, as you properly noted, is that the Fords and Ferraris have a bigger advantage on the high speed, low down force tracks than they do on the other tracks, so the series' attempts to balance the cars doesn't work there without additional changes. We saw the same thing at Le Mans last year, and since those are the only two races to work with for the high speed/low downforce races, the series doesn't yet have enough data to make the right decision. The rest of the year's races(outside of Le Mans) should not have a similar imbalance, as they have all of last year for all of the cars (except the Porsche which is new) to try to make the cars equal.
So, as I've said several times on this forum, no one should be too high on Corvette Racing if they are much faster than the other teams, or too low if they are slower. Those things just mean that the series had done a poor job in their objective to balance the cars. What you should be happy with, is when all the cars are about equal, and Corvette still wins, such as what happened in several races last year. That means the series did its job in balancing the cars, and the Corvettes won on strategy, teamwork, driving, reliability and consistency.
Old 02-16-2017, 03:27 PM
blkbrd69
blkbrd69's Avatar
I will never be able to figure out BOP. I know its needed but really?
The 911 was running a mid engine. How is this production car based? Looking in the back of the 911? with the rear bumper cover off, you could see the tub had an area for a spare tire where the engine should have been.
It would not surprise me if the year the C8 comes out GTLM goes away replced by exclusively GTD/GT3.
Old 02-17-2017, 10:11 AM
rfn026
rfn026's Avatar
I had this very same discussion with a Corvette engineer yesterday.
You have to compare the Corvette race team to the Patriots. They have a very clear philosophy of "Just Do Your Job".
Doug Fehan is in charge of the drivers.
Gary Pratt is in charge of the cars
Bill Miller is in charge of the money.
No one screws around in another person's area. Plus, they have all been together from day one.
Then we have Dan Binks. Dan has been with Gary forever.
It works. Organizational stability can never be underestimated.
Richard Newton
Compressed Air for Your Shop
Old 02-17-2017, 02:41 PM
blkbrd69
blkbrd69's Avatar
http://www.imsa.com/news/022017/34-e...test-next-week
Good article about the upcoming Sebring test and some info on the Corvette team.
To Why Does the Corvette Racing Team Win so Much?
Quick Reply: Why Does the Corvette Racing Team Win so Much?
