rubber accumulation on tires
is the accumulation of rubber on tires built up from your tire or picked up from the track or ?
what/where/how does this come about ? what is it a sign of and can anything be learned from it ?
thx
thx
Here's an F1 Tire
I prefer the propane bottle and a putty knife
This is not a fun job. I usually put it off until the middle of the week.
Richard Newton
Tools for Your Tires
Here's an F1 Tire
Richard Newton
Does this count as a "Heat Cycle"
rfn026 (03-26-2017)
Here's an F1 Tire
Richard Newton
I just did the blow torch putty knife routine yesterday. Worked great actually.
rfn026 (03-29-2017)
Received 8,924 Likes
I just take them out on the track and after 4 or 5 hot laps the rubber comes off.
Bill
Bill
Bill
Bill
Bill
I purchased a set of Continental Slicks from GT Racing Tires a couple of years ago for my C6Z. A couple of the tires had a fair amount of other people's rubber on them and when I took the car out for the first lap around the Glen it was bumping like hell. On the third lap the bumping got a lot better but then I started hearing a banging noise in the rear. When I pulled into the garage the rubber was smooth but the driver's side wheel well was filled with a big ball of rubber about the size of my fist and one of the other guys who had been on track with me came by to say I was throwing big chunks of rubber at everybody I passed.
Bill
Bill
Good question OP. Was wondering what to do with mine, big gobs on the tread like Richards above. Tried spinning the tires, weaving, etc to no avail. After about 3 laps the rear tires felt like they were both flat and about to come off the rims. Do you think it's due to the rubber build up, or are they in fact heat cycled out? PSS with 6/32s tread left.
I don't have fenders on my car, so I can literally see the rubber build up and scrub off in real time. It's amazing how much rubber moves around the width of the tire.
I pretty much always use scrub tires, but the last ones I got had a lot more build up than any I had used before. When it takes 4-5 laps out of a 20 minute session to get rid of the chunks, it makes me think it's time to start scraping them.
Ken
I've never even considered the rubber accumulation a problem. Even huge buildup seems to come off by the time the tires are up to operating temp, or the lap after. I guess if you are playing F1 racer and need immediate grip as soon as you pull the tires out of the warming blankets you need to scrape it off
What I have found more troublesome is the rubber buildup INSIDE the rim where you might put balance weight. Enough rubber there will change your tire/wheel balance. Easy enough to remove of course.
Hate the chunks! The inner barrel is easy to chip off but welded onto the outside tread is tougher. I just run 'em and they self clean, but wish I could start with balanced wheels.
Once I proved to myself that my tires were turning on the rims...I stopped balancing track tires and wheels. In nearly 15 years of track events, I can't say I noticed the difference between balanced and "unbalanced" track tire and wheel combos.
My coach Eric says it's from driving offline, so stick to the line better.
It can create annoying vibration but I don't think it's dangerous unless you're at the absolute limit.
Correct, but need to go off line in order to pass, so unless you are constantly being passed, you will have to go off the line at some point.
