metal to metal sound from front left wheel when turning?
Old 05-25-2004, 10:13 PM
Red5
Red5's Avatar
Default metal to metal sound from front left wheel when turning?
Just started today. When I turn hard right I get a metal to metal sound... Sounds like my steel braided brake lines were rubbing the rim. But I checked and found no rub marks.
I also didn't notice any play in the wheel bearing and it turns fine when off the ground.
Any ideas on what would cause my drivers side wheel to make a slight metal to metal sound when turning right?
Old 05-26-2004, 02:49 AM
McShagger
McShagger's Avatar
Default Re: metal to metal sound from front left wheel when turning? (Red5)
is it a grinding/rubbing noise or a clinking noise?
Old 05-26-2004, 03:00 AM
McShagger
McShagger's Avatar
Hey man,
What is that on your front LP area?
Old 05-26-2004, 08:08 AM
Red5
Red5's Avatar
Default Re: metal to metal sound from front left wheel when turning? (McShagger)
More of a grinding sound. It sounds like the metal brake lines are rubbing the inner wheel, but there are no marks, so I don't think that is what is happening.
Im hoping its not a wheel bearing going out.
I don't know what you are asking in the second post.
Old 05-26-2004, 02:37 PM
Z11409
Z11409's Avatar
Jack car up and spin wheel,shake wheel,look at caliper to make sure its tight--If you have more than 15,000 miles,proably a wheel bearing
Old 05-26-2004, 02:59 PM
Red5
Red5's Avatar
Default Re: metal to metal sound from front left wheel when turning? (Z11409)
I have close to 90k on the car...
What are the signs of a bad wheel bearing?
It only does it when I turn right.
Old 05-26-2004, 03:07 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
check for rocks around the caliper. I have seen them pick up rocks and scrape against rim/rotor. Just a thought.
Old 05-26-2004, 03:34 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
try turning on a flat surface and see if it repeats. Jack it up and see if there is freeplay in the bearing and rotate the tire to see what you feel.
Old 05-26-2004, 04:43 PM
Red5
Red5's Avatar
Default Re: metal to metal sound from front left wheel when turning? (John Shiels)
I will remove the brakes and check them.
When I turn the wheel it turns fine. No sounds or woobling.
One thing that is a little strange:
When I tighten the wheel lugs on the front left wheel. I get them tight... And then the wheel re-adjusts and I have to re-tighten it. It's like its getting caught on a lip around the bearing area. has this ever happened to you guys?
BTW: John, you should have recieved a check by now. Feel free to let it clear before shipping out the headers and X pipe.
Old 05-26-2004, 10:42 PM
davidfarmer
you're scaring me.........
Old 05-27-2004, 09:25 AM
cire96
cire96's Avatar
Red 5:
If by "turn hard" you mean turning the wheel to the locks, and you have wide rims, it might be that the inside of the rim is rubbing on the lower control arm. That a very common interference in C5's with wider than factory front rims.
Cire
Old 05-27-2004, 09:45 AM
z060ntrack
z060ntrack's Avatar
Default Re: metal to metal sound from front left wheel when turning? (davidfarmer)
I had a student once that picked up a bolt and it lodged itself between the caliper and rotor.
Old 05-28-2004, 01:54 PM
McShagger
McShagger's Avatar
Sounds like wheel bearings...
What is that deal in your front lic. plate area?
Old 05-29-2004, 02:21 PM
Red5
Red5's Avatar
Front license cover..
Tango Golf Mike
The Green Machene
Remember the old big wheels that you could drive with the rear axle?
Old 05-30-2004, 10:57 PM
MNCrystalRed2011
MNCrystalRed2011's Avatar
Once you have it jacked up, grab the wheel at the 6 and 12 o'clock position and try an rock it back and forth. If you feel a slight wiggle and a bit of a clunk (for lack of a better description), and you will know if it wiggles, your bearing is shot and needs to be replaced ASAP.
To metal to metal sound from front left wheel when turning?
Quick Reply: metal to metal sound from front left wheel when turning?
