Speedometer metal drive gear problem
I had a 4:11 rearend and installed a 3:36 for better driveabilty. Problem is the Transmission has a 20 tooth gear for the 4:11 and I need to go to a 18 tooth gear for the 3:36 for accurate MPH reading. The book says the metal drive gear in the transmission has to be changed if you go to the 3:36 from the 4:11 to match up with the 18 tooth plastic gear. Is there any other way to do this to get the right MPH or Just live with the 10 MPH to slow a reading untill I have to remove the transmission at a later date for whatever repairs that it may need at that time and install the larger metal drive gear then.
Billy
Billy
Another option is to use a speedo gear box adapter. It is a small gear box that couples directly where the cable goes now, and then the cable connects to the adapter output.
They come in many different ratios, and should be available at an "old time" speedo shop for about $100. I got one for Evergreen (fellow Vette forum guy who resides on an island off Alaska) a couple of years ago. I am in the process of moving from IL to FL this coming week, so please don't ask for me to get you one!
Plasticman
Plasticman
Billy
Billy
EVERGREEN
With the limited room avalible behind all the shifting rods on a 63 T-10 transmission I would think a gear drive unit would not fit to good. The late 65 and later have the output speedometer drive on the right side of the transmission and would be no problem. Have you installed a gear drive unit on a left side output and had room to do so on the 63-65 early cars? Thanks
Billy
Billy
the Transmission has a 20 tooth gear for the 4:11 and I need to go to a 18 tooth gear for the 3:36 for accurate MPH reading. The book says the metal drive gear in the transmission has to be changed if you go to the 3:36 from the 4:11 to match up with the 18 tooth plastic gear. Billy
My parts manual shows the following gears:
ratio__tire size___drive gr_____driven gr_teeth_color
2.73__8.15-G70__3895494____3987918_18____brown
3.08__7.75-15___3924098____3987918_18____brown
3.31__8.45-G70__3924098____3987919_19____natural
3.36__8.15-G70__3924098____3987920_20____blue
3.55__8.15-G70__3924098____3860344_21____red
3.70__8.15-G70__3924097____3860345_22____green
3.70__8.45-_____3924098____3860344_21____red
3.73__8.15-G70__3924097____3860345_22____green
3.73__F70______ 3924097____3860348_25____orange
4.10__8.15-G70__3924097____3860347_24____yellow
4.11__F70______ 3924097____3860348_25____orange
4.56__8.15-G70__3924097____3860345_22____green* uses 3890575 adapter
The 18 tooth gear is for 3.08 ratio diffs. What wheels and tires do you have?
Billy
Billy
Have the name, address, and phone # of the place that John got mine from if you need it.
EVERGREEN
Magic-Nice info,thanks. I got my #s wrong in the first post. Must have had a brain fart. I removed a 25 tooth and want to install a 20 tooth. I have Goodyear Eagle GT-HR 215/65R/15. OD is 26". Would the 20 tooth be correct?
Evergreen- Thanks for the info also. Yes I would like the #s to get hold of someone to supply the part I need. Thanks
Billy
Billy
is there a ratio box for the tach?
Going to a HEI tach drive distributor for a 1960 and would like to replace the generator with a 1 wire 100 amps alternator .. so i understand if i connect the tach to the HEI tach drive distributor it will read 1/2 what it is suppose to.. i think i need a box or somthing that will 2x the reading i ? Do they make such an item or do I have to take out the entire dash and recalibrate the tach unit?
Received 1,856 Likes
If you're switching your tach drive from the original generator-driven cable to a distributor-driven cable without changing the tach, you need a ratio box that doubles the cable speed; otherwise you need to have the guts of the tach changed from "Reads cable speed" to "Reads 2X cable speed".
Before you buy a 1-wire alternator, you might want to read this:
http://www.madelectrical.com/electri...evymain1.shtml
I don't know if there are any boxes out there to do the 1:1 or 2:1 conversion but if you take the Tach out you can fix the problem by simply recalibrating it...This is probably the most inexpensive way to go.
Jason
billy - "I have Goodyear Eagle GT-HR 215/65R/15. OD is 26". Would the 20 tooth be correct?"
27standard/26new tire height is 1.0385 which means your speedo cable will turn 3.85% faster. To slow it down (assuming your speedo was correct with a 25tooth gear and 7.75x15 tires) you would need 3.85% more teeth on the driven gear - or a 26 tooth gear to accomodate the tire change.
Working from that point - switching from 4.11 to 3.36 ratio diff gives a ratio 4.11/3.36 requires 22.3% fewer driven gear teeth to speed up the cable via only driven gear change - or - 21.26 teeth on the driven gear.
The 3924097 drive gear does not have a 21 tooth driven gear. If you install the available 22 tooth gear, your originally accurate speedometer will read 3.4% too low.
I would change to the green gear before tearing out the trans and changing the drive gear. The tire heights are always suspect, and a reality check with the new rear and the small tires is in order.
My memory tells me the number of teeth on the drive gear 3924098 is not the same as 3924097. The driven gear teeth will have to be recalculated to accomodate that change, if you make it.
IMO, if you have a 3.8% speedo error after tests, the easiest change is to get 25.125 inch high tires on the car.
Magic
Wow what math and good info. I can live with 3 or 4 MPH to low a reading before I would remove the transmission. I will change to the green gear and give it a run. Is this a great forum or what. Great info and great people.
Billy
Billy
