Which roller rockers fit under stock aluminum valve covers
Do any of the true roller rockers fit under the stock 63-7 aluminum valve covers? I know the roller tip rockers fit, but i would really like to find some true roller rockers that will fit.
Pic one-roller tip
True roller rocker
Oh, and do these actually add 10-15hp. Anybody tested them on a dyno??
Pic one-roller tip
True roller rocker
I purchased my 60 with aluminum valve covers over Harlan Sharpe roller rockers. They will not fit under aluminum covers that have molded in drippers. My 70 has these valve covers.
The stainless steel roller rockers shown above bottom picture will fiit under the stock BB steel valve covers, but you have to remove the drippers.
I am running them on my BB.
Received 1,857 Likes
Roller rockers vs roller tipped rockers.
Pic one-roller tip
True roller rocker
Pic one-roller tip
True roller rocker
Roller rockers are nice, I use them with the late model aluminum covers. I don't see any real difference in performace one vs the other in a street application. Their claims about 10 to 15 hp increase might be a little over the top.
They can help with valve guide wear if the geometry is correct. If the push rod is not the correct length it won't help a lick. Manley makes a slick plastic checker, cheap and does the job. Most stock engines will be in the range, more radical combos or the use of after market heads will need checking. My 67 chevelle with the GM fast burn aluminum heads, roller cam , decked block has .200 long push rods.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I have ROLLER TIP rockers on ALL my SB engines with stock valve covers (finned alum), no problems.
Thanks, i have been using the roller tip design for a few years now, but i was hoping that a full roller version might fit under my 65 aluminum small block valve covers. Oh well-i guess i will keep that money for something else.
BTW, just got the Lunati voodoo 60103 cam in. I guess we will soon see if these cams are as great as holley claims.
I purchased some of the magnum roller rockers a couple years ago. They fit fine, but the licking nut is what got in the way. If somebody made a shorter nut for the center of the rocker,whatever that piece is called, then it would work great.
Corbra, I'm running the 1.5 Forged Magum's also and I just not only ran the thicker gaskets but also took my dremel to the spots where my poly locks hit the valve covers... I too wish I could go to a full roller setup but I like the finned covers as you do....
I know this might be getting a little silly but how much room do you guys think you would need to get a full roller system under the finned valve covers?? Glue two of the thick gaskets together or would that still not be enough? Dave...
Cruise-In III Veteran
Cobrastang, youwish2beme & Others here,
Send me a short message via e-mail to jkaram@wideopenwest.com and I'll send you some pics of my setup (don't have a hosting site) that does use 1.6 Crane Gold Roller Rockers with no valve cover interference...I'm using the factory aluminum valve covers. They work using 1 set of cork gaskets. Did have to have a set 8.25" push rods made to take advantage of the increased ratio.
Go for it!
Jim
Go for it!
Jim
I replaced the stamped steel chevy stock rockers on my 435 with the comp cams roller tip rockers shown above, they are investment cast rockers with a roller tip as you already know.
I ran them for a few days and one of my pushrods almost drilled its way right through the rocker pushrod seat...I learned later that they are not designed for anything more than bone stock specs and should not be used for high lift or high performance valve springs....after I saw this I replaced them with Norris Cams stainless steel roller rockers and never had a problem again... Same as comp cams version today, in stainless steel
I have been tempted to get a set of original Corvette aluminum valve covers for my 65 and fabricate some aluminum spacers for them to fit over my roller rockers. I currently have some Edelbrock aluminum valve covers (I will never go with stamped steel again ), but I like the factory look better.
1)--How thick would the spacers need to be to clear the roller rockers? I am guessing around 1/2".
2)--Would anyone else be interested in having the same thing fabricated? This sort of machining cost per unit is much cheaper with volume. I will work on the CAD to send the specs to the machinists next week and get a price per unit for one set, five sets, twenty sets, etc. Send an e-mail to rocksolidflooring@msn.com if anyone is interested.
Originally Posted by nitram
No need to have spacers custom built. Their available from Jegs now.
