'65 327 block?
'65 327 block?
I need some help decoding a SBC and I hope that you guys can help me out.
Passanger side infront of the head reads:
YYY001897
T0905HV
The suffix code comes up with 327 block with 350 hp
the block casting number
3932888
I can't find this number anywhere though
the head number is
333882
which I found to be 74-80 350-400 heads with 76cc chambers..
Can anyone here help me out with this?
Thanks Rob
YYY001897
T0905HV
3932888
the head number is
333882
Thanks Rob
Received 1,857 Likes
3932888 is a late 60's-early 70's 350 truck or passenger block, and the 333882 heads go with it. The "HV" suffix says it was originally a '69 350/255hp 4-barrel from an Impala/Caprice.
Thanks JohnZ
Could you tell me where you looked that up? I would like to know if it has compression ratio, 4 bolt or 2 bold main? anything like that. It has a Performer RPM intake and 600 cfm carb on it and it runs like a sick dog.Might just need rebuilt with alittle more compression.
Rob
Rob
Received 3,043 Likes
St. Jude Donor '05
Good friend of mine has a 65 replacement fuelie motor for sale;just gone through, non original heads and intake;comes w/Powerglide, exh. manifolds, needs to sell it-Can't find my thread on it-818-998-5455, ask for Keith
Originally Posted by RobBob91
Thanks JohnZ
Rob
Rob
I am sorry the whole time I have been trying to decode the casting number I was reading it wrong. The number was 3932388. thanks everyone for the help I found the code and am good to go.
Rob
Rob
