Steel Body Jig / Dolly - Anyone Interested
I will be building a fully adjustable, steel body jig w/ rotating wheels in order to do a frame off on my 66. The jig will be capable of handling coupes or convertibles and will be adjustable to handle any year vette.
If anyone is interested in purchasing a jig, please let me know and I will considering building 2 right away.
SAS
SAS
Will the jig be capable of rotating the body? I have looked at several different rotisserie type rigs and none of them can handle a vert. I have much work to do on the under body of my 65 and don't relish the thought of doing it lying on my back.
Help on inserting a picture
can someone direct me on how to insert a picture.
I had used a seperate website that started with a T before.
Scott
Scott
Here is a picture of the one we made for our square tube frame body dolly a couple of years ago. It is very stable and can be positioned for either side. It sure has been a back saver
Rich Lagasse
2019 Corvette of the Year Winner
St. Jude Donor '15
ok...I will bite...how much? If you make it so that it bolts together, then all that would have to be done is to put the kits together and ship them out......I either get one of these or make a dolly or........I am in the process of getting ready to pull the '60 off the frame...not quite there at the rate I am going, BUT it is going to happen soon.....
Body Jig
I am in the process of compiling the material costs. Once completed, I will contact the interested individuals with an estimated price.
If you are interested, send me your e-mail address so I may send you a picture of my intended design.
I am unable to add a picture at this point in time - I know it takes the use of a seperate internet site, but I do not know the name of the site right now.
SAS
SAS
Originally Posted by noelga
I have one we built and will be done with it in Jan.
Great looking item, built to very high standards it seems. Shipping might just a bit of a beotch though
Originally Posted by richscorvettes
One option to consider for the body dolly is a "body tilter" which allows the body to be positioned on it's side. The frame for the tilter fits into the square tubing of the dolly and can be removed when not needed.
Rich Lagasse
Rich Lagasse
That is a great-looking device, yet seems simple in its design. I notice you had the front end removed, which is what concerns me. My front end is still attached to the car, and I worry about supporting it while the body is rolled to the side.
Are the legs that are resting on the ground reversible to roll the body in the opposite direction?
Thanks, Bob
Rich,
Thanks, Bob
Thanks, Bob
We had thought of a few different approaches to making the tilter and came up with this one which is straight-forward and easy to make. The tilter arms slide into the tubing of the dolly and can be switched to tilt either side of the body dolly. Like the adjustable uprights on the dolly itself it is held in place by welded nuts and bolts.
At the time that picture was taken the front end was off the car but there is an adjustable support arm on the body dolly that mounts to the radiator support to support the front end which has worked very well.
Rich Lagasse
Body Jig - Frame off restoration
I have completed my first body jig and I am willing to produce more. If you are interested, go to e-bay auction Item number: 4601076372
If you have any questions, please let me know.
NOTE: In the future, the rear offset arms will be mounted on the side frame rails, lesson learned with mine.
Again, if you any questions, please e-mail me at nvr_enuf_sas@yahoo.com
