need help with intake numbers
1 Post
My 62 did not have the intake manifold. I bought one years ago from a chevy dealer. Please tell me what it is. Number 3844459, GM3, date appears to be H217? What is this and what carb is it for. I have a AFB on this manifold. I see two on ebay
1.item 8022601165 number 3799349 300 hp
2 item 4596958098 number 3793244 250 hp
Would one of these be better for me or am I ok the way its been for over 20 something years.
Intake manifold #3844459 was originally used on 65 C-2s w. 300 Hp. The date H217 indicates a service replacment . Intake #3844459 used AFB carb. model 3721S, SA, or SB w. manuel trans or model 3720S, SA or SB w. Powerglide trans.
My 62 came with manifold #3799349, which the books say is identical to your manifold #3844459 (w/add. of power brake boss). Manifold #3799349 was designed for years 63 & 64, however was used on late model 300 hp 62's, which my 62 is, so appears to be the correct manifold for late model 300 hp 62's.
Appears that from a performance view, your current manifold will work fine (as you indicate). But if you want numbers matching then #3799349 appears correct for late model 62's of 300 hp.
The matching carbs for 62 appear to be
1) #3269 S (4.5) for manuals & 300/340 hp
2) #3310 S (4.5) for automatics & 300 hp.
Hope this helps.
Hope this helps.
