Need some info on a 3959512 Block
I'm looking at a 3959512 block and need some advice.
Block - 3959512 / Pad - CE 5n2-5
Crank - 4577X
Heads - 3782461
I don't have the cast dates but am trying to run those down. My thoughts are this is a 1965 CE engine and if I'm replacing the engine in my 1965 this would fit better than a correct cast number / wrong date code.
I thought I was looking at a large journal block, but the 4577 crank points to a small journal block. What does the x stand for?
Any input on that line of thinking would help.
PS - could this block be line bored to take a 350 crank?
Crank - 4577X
Heads - 3782461
Originally Posted by Seaside63
speed-o-motive offers a 383 stroker crank for the small-journal 327 blocks. Try them for a 350 crank.
I know chevy made this 3959512 block as a service replacement with large journals in the early to mid 70's (this was talk about on another thread). If I could line bore this block from the current 2.30 main to a 2.45 main I would just swap the LT1 rotating assy to this block.
I don't recall reading anywhere about this ever being done. I have a 327 crank and could easily build this up as a 327, but was just wondering if this is doable.
To much coffee and thinking.
