What oil filter?
What oil filter?
Does anyone know the correct oil filter for my ZZ4 GM crate motor? I need the part number and manufacturer of a compatible one.
Received 6,943 Likes
2015 C2 of Year Finalist
I belive AC delco 1218 will work
Originally Posted by prseasix
Excellent! Thanks! BTW, the engine has around 3,000 miles. Do you recommend switching to synthetic for this oil change?
Originally Posted by Kensmith
Synthetic, 50/50, or you can go with Royal Purple. Just need to check the weight and use what the manufacturer recommends.
Received 1,857 Likes
Originally Posted by Blk63Vette
Hi
I can not remenber if the condensor goes on the negative or postive terminal of the coil.....
Help Im losing me mind
