1962 Vin ?
Old 04-09-2006, 11:56 AM
Corvette ED
Corvette ED's Avatar
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes on 1,033 Posts
Default 1962 Vin ?
Is the VIN stamped into the frame anywhere on a 1962 Corvette?
Old 04-09-2006, 01:01 PM
Donald #31176
Donald #31176's Avatar
The VIN is stamped on the left side member of the frame in the center. I believe the body will have be be lifted to see the impression.
Old 04-09-2006, 06:25 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
It's stamped on the top surface of the main side rail on the driver's side, about 1/4" from the outside edge, directly in line with the center of the "X" member, about where your wallet is when seated. You may be able to see it with a mirror if you use a tapered wood wedge (like a doorstop) on top of the frame to move the floorpan up.
To 1962 Vin ?
Quick Reply: 1962 Vin ?
