Headers=YES Alternator=NO HELP
Since I added headers to my 64 vert my alternator had no place to go. I purchased the Mr Gasket F bracket that mounts to the headers along with another bracket that mounts to the alternator. You hook the two together and are supposed to have a working alternator. Brackets won't adjust enough to line up alternator belt groove with water pump pulley.
Anyone got a solution for me?
When you start modifing from stock ie headers you sometimes have to make more modifications. I would think that you could modify the brackets by slotting them more so that you can get the adjustment you need. Dave
St. Jude Donor '08
If you can't rework that bracket asembly, and you have the mount holes on the front surface of the head where the alternator needs to mount, you might want to check out summitracing.com. Type in " zoops correctalign " in the search box at the top of the home page, scroll down the page, and click on the pictures for a detailed description of the mount position.
Pieces are polished billet aluminum. They're not cheap, ( $157.00 for the alt. bracket ) , but they allow 3/4" fore/aft adjustment for belt alignment. Available for long or short water pump applications, outboard drivers side or inboard pass. side mount.
BTW, read your post about your persistence in pursuing your dream , and finally hearing yes. I'm impressed.
Hope this can be of some help to you, and best wishes for your continued progress.
Originally Posted by Jack60
Without seeing your brackets, if you can not slot them, can you use spacers to move alternator forward more, or does it need to go back?
Needs to come forward about 3 inches. Slots won't allow sliding forward that much.
I don't see any part numbers on it...maybe someone else can id it ?
Is that a stock bracket mounted to the block?
St. Jude Donor '05, '09, '15
http://www.jegs.com/webapp/wcs/store...0363&langId=-1
part #520-10922
Alternator Bracket
I would advise not to use the bracket that bolts to the header. I have tried to use them multiple time over the years and they always break. Heat and vibration just doesn't prolong the life of these brackets.
Originally Posted by Sky65
Which side is the alternator on, pass or driver. If it is on the passenger side, which I think it is, you may have the wrong bracket. Mr Gskt and most aftermarket brackets are for the drivers side mount. Hooker makes a passenger side mount, JEGS sells them. I know because that is the problem I ran into on the 65.
part #520-10922
part #520-10922
I do have the Mr Gasket bracket. I think you just solved my problem. I ordered the bracket from Jegs!!!
St. Jude Donor '08
Like Sky65 said Which side is the alternator on, pass or driver. If it is on the passenger side, which I think it is, you may have the wrong bracket. Mr Gskt and most aftermarket brackets are for the drivers side mount. Hooker makes a passenger side mount, JEGS sells them. I know because that is the problem I ran into on the 65.
Passenger side.
