Pin hole in oil pan; 1964
I thought my oil drain plug was leaking when I dicovered a pin hole in my oil pan right next to the drain plug; anyone know of a fix for this?
Spot weld from the inside. The easy thing to do would be to buy a new pan. But if you are trying to keep it original, take the pan off and take it to a welding shop. Ask questions before leaving it with them. If you don't like answers go to next shop.
Received 1,843 Likes
If you're not willing to pull the pan at this time, probe around on the pan in the area of the pin hole with an ice pick and see if you can "find" anymore leaks. If not, you can run an appropriate size sheet metal screw in the pin hole to plug the leak. Pull the pan and fix it right after driving season is over. If the hole is overlapped by the threaded bung in the pan, this won't work.
It's a simple matter to pull the pan. Why not just do it?
Fix it before it becomes a bigger problem.
Had an altered roadster (drag race) that had a very low oil pan. Running at a track way out in the boonies. Made a pass, and then the tow car came down the track and pulled me back to the pits down a very rough return road. Got to pits to see a line of oil back up the return road. Yep, the side mounted oil drain plug had gotten unscrewed by the road. Easy to find the plug at the end of the oil trail!
plasticman
Either do this or pull the oil pan and if the area of the hole is still good weld away or replace with new oil pan. I would try the PC-7 Epoxy first.
Good luck!
If the pin hole is right at where the thread boss meets the pan sheetmetal, any welding shop can brass braze the hole shut. If the hole is in the sheetmetal itself a little ways away from the thread boss, have them braze a knockout slug from an electric switch box (or other small piece of metal over the hole on the inside of the pad.
If the hole is not there from outside mechanical scrapes or other trauma, it is probably from inside rust, and there may be more bad spots so pan repalcement may be the best idea.
Doug
Doug
If you want to keep the car original you will probably have to get your pan repaired as original pans are no longer available. The replacements are $120.00, "look different from original and you must change the oil pickup".....according to Corvette Central catalog.
Doug
Solder works but also use a small patch. Thin sheet of copper or metal.
Welding the pan on the car = KABOOM
If you go the epoxy route, use a small sheetmetal screw in the hole. Barely make it tight so the epoxy makes a seal.
Originally Posted by ffas23
How the heck can there be inside rust in an Oil Pan filled with Motor Oil?
Doug
maybe there was a coolant leak into the oil at one time, maybe the PCV valve didn't work, and a lot of water vaper condensation was present. Maybe the pan is a junk yard replacement and it got rusty in the junkyard.
Doug
Doug
