Question About Steering Wheel Hub For '67
Hello,
On my '67 (non telescopic wheel), there are a couple of the steering wheel mount screws that will not tighten because the threads in the hub are stripped. Therefore I have been looking for another hub. In the Corvette Central catalog, they only list one for a telescopic wheel at about $55.00. Then in the other catalog that I have (Volunteer), they list one hub as fitting both tele and non-tele cars for $115.00. I'm a little confused as to which hub I would actually need. If any of you guys could help, I would appreciate it...I'd like to get my steering wheel tight again!
PS: if any of you guys have a good used hub, that would work as well.
Rob T.
Rob T.
Originally Posted by 75SHARK
Hello,
Rob T.
Rob T.
Roy
St. Jude Donor '05, '09, '15
The 67 wheel is differant than 63-66. The center spoke lays under the other two at the hub. The hub therefore has a notch machined in it for the center spoke. I don't know if the hub it'self is differant on a tele steering columm from non-tele.
Received 1,857 Likes
'67 standard and telescopic both use the same hub.
Me too....
[QUOTE=rongold]I helicoiled my original one many (at least 15) years ago, and it is still holding.
same here - I did the Helicoil trick in 1990 and they're still holding just fine! I also recommend using a little Locktite on the screws when you reinstall the wheel, as I once noticed 3 of mine were loose at the same time! Not a pleasant thought to contemplate the wheel coming off in your hands while you're going around a corner.....................
