Front end alignment
Front end alignment
I have a 57 with original fron end and radial tires. The front end was aligned with factory settings. The tires are wearing. I was told that the alignment settings should be a degree or two different for radial tires. Is this true and if so does anyone have the correct settings?
Received 1,856 Likes
The only setting that needs to change is toe-in; radials want zero to 1/16" TOTAL toe-in, the old bias-ply tires needed much more.
Front camber - zero degrees
Front caster - 3 to 3-1/2 degrees (with power steering - you may prefer less with manual steering)
Front toe-in - zero to 1/16" TOTAL toe-in
Rear camber - zero to 1/2-degree negative
Rear toe-in - 1/16" TOTAL toe-in (1/32" per side, split equally across the thrust centerline).
I wouldn't drive a car with 1/2" spacers.
