63 SWC air conditioning
I have a 63 SWC and would like to know if it is possible to get air conditioning installed, how much of a job it would be, and (ballpark) what it would cost.
There is a company called Vintage Air that does a great job. I have it in my 63 SWC and it looks original and works great. It was in it when I bought the car in April so I'm not sure of the price. I think between $2000 and $2500. It's well worth it. You may have to replace the cooling fan with a 6 blade fan to avoid overheating. Depends on where you live.
CF Senile Member
I installed Vintage Air in my 63 Coupe several years ago. It was a lot of work. When you open the box, it seems a little overwhelming. Once you organize everything, and start through the instructions, it starts coming together. It is a lot of work, and takes a considerable amount of time to get everything installed (ducts, under dash box, compressor / lines, condensor unit, etc...). Have help - lots of things the require more than 1 set of hands.
As for cost, it is kind of like that joke that was on here the other day about oil changes. If you count Beer and new tools that you use this as an excuse to buy, it is very expensive. After the installation, I was fighting over-heating problems when running the AC. I ended up putting a DeWitt radiator and electric fans in to resolve that issue. It all works good now, and engine stays cool. The actual cost of the Vintage Air unit was about $1,800 4 years ago (this includes the cost of a new radiator and fans). Good luck.
Dave
Dave
Thanks alot "Vettefrenchee" and "63C2splitter". I will try to contact Vintage Air and see if they can point me to anyone who can do the job in the Harrisburg, PA area. "63C2splitter", since you ordered the unit from the company, do you have an address and/or phone number?
CF Senile Member
I think I bought it from Corvette Central. Attached is a link to a similar unit. The cost seems lower than what I paid for the "Vintage Air Unit". I was reading the info sheet on this and it says it should be installed by a "professional" - they didn't tell me anything like that when I bought mine.
http://www.corvettecentral.com/newsletter/200605251.htm
Here is the Vintage Air home page.
http://www.vintageair.com/
i want to add AC to my '65 coupe.
did a bunch of research........ the "kits" from the different AV vendors such as Vintage Air, Classic Auto Air, etc typically run $1250 - $1500.
You can install it yourself although it's a bunch of work but thast's what I plan on doing.
Before I decided to do it myself I shoped around at a number of "Corvette specialty" shops to see how much they wanted for the system and installation. EVERY single place I spoke to wasn't thrilled about doing the job, said it was a real PITA, but they would do it and the average price between all the shops was $5500!!
yep, they wanted about $4000 labor to install it for 2-3 days work.
Forget that, I'll do it myself!
BTW, when I compared systems I was more impressed with the Classic Auto Air system than the Vintage Air system although many use the VA and are pleased. Either one should work fine whichever you choose.
CF Senile Member
Mike is right, the kit is a little over a thousand bucks, then add some for belts (you have to relocate alternator to drivers side - and I updated the Alt to a larger unit), new radiator in my case w/fans $650, and othr miscellanious stuff. The total cost in my case was close to $2K. I don't regret adding the unit.
Dave
Dave
Roy
CF Senile Member
I had no idea they wanted that much to install the system. I guess I don't mind the amount of work it took now. It definately isn't that hard. 67-427 said it best - the learning curve is very steep. I could install it now in much less time.
Dave
Originally Posted by 63C2splitter
Wow!!!!
Dave
Dave
Now that i'm doing my own work on my car I'll tackle it myself as a winter project so it it takes me 20, 30, or 100 hours it won't matter.
No way i'm shelling out $4K to have someone else install it.
It's obvious to me that the installation is way out of my league, so I will probably have to enjoy driving on the cooler days as usual and forget about A/C. Thanks for all the info everyone.
Roy
CF Senile Member
Originally Posted by 67-427ci
Don't sell yourself short so quickly on installing A/C. You don't need any special tools and the instructions (from Classic Auto Air) are step-by-step, VERY detailed with lots of pictures. Plus with all the help you get on this forum it is pretty easy. Maybe there is a forum member near you that has done an installation that might give you a hand. I would be happy to assist if you were near me.
Roy
Roy
Dave
That's great encouragment! Maybe I'll think about it over next winter. I'm much better working with wood (making violins) than busting knuckles and swearing at engines.
11 months ago I was too scared to do ANYTHING on my own car. I didn't even know how to change the oil or set timing. I needed help to replace a fan clutch and that is only 4 bolts!
With the help of everyone here on the forum I do not take my car to a mechanic anymore and i'm doing everything myself and I have no problem deciding to tackle the AC installation myself as a winter project.
Believe me, there probably isn't anything that others on here have not encountered and they can help you get thru just about any project you decide to take on to do yourself.
All you need is the willingness to learn and take on the project yourself and mentally getting over the "intimidation factor" of doing something you have never done before.
Oh, there will always be some degree of screaming, cussing, and frustration somewhere in the middle of the project, but you just keep working on it until you get it done right and there is no greater satisfaction than knowing you did it yourself (especially when it comes to saving $4K!!)
63 Air
I agree with the above. Don't sell yourself short. Before I bought my Vintage Air system, I down loaded the instruction booklet from their website. I read it a few times and am preparing myself for the install when my body comes back from the paint shop. PM me if you can't find the instructions and I can send you a copy. Jerry
Tampa Jerry - That is great information. If I see the instructions, I can decide whether I can/am willing to try to do it. I will look for the instructions at Vintage Air and if I can't find them, I'll send you a PM. Thanks!
And again thanks for the encouragement to everyone else.
Dick, I see that you are also a member of Central Pa. Corvette Club.
I agree with most of the replys. You can install the AC system with a little patience and good instructions. Good luck.
Dave Gray
Carlisle, Pa.
Dave Gray
Carlisle, Pa.
