Need some Holley Help!
I found the fuel inlet leaking on my Holley -- #80457-2. Turned out to be a stripped inlet so I ordered a new primary fuel bowl kit.
It'll take about a week to get here. In the meantime I rigged up a brass fitting into the old fuel bowl with about 1/8 inch more bite and a brass elbow with a fuel nipple to my fuel line.
Good news is... the leak stopped.
Bad news is... when I start up the engine... fuel spills at a high rate into the secondaries...flooding out the engine.
The primaries seem to be operating fine....and the engine runs great for about 3-minutes....but fuel continues to pour into the secondaries until it floods them out. And continues to run (not drip)....for up to 5 minutes after I turn off the engine.
What's going on here? I never touched the secondary fuel bowl!
Do I have too much fuel pressure coming in now?
Any help would be appreciated. -Thanks.
I assume that there is a fuel feed tube between the primary and secondary fuel bowls and a metal shaving from the stripped threads has traveled to the secondary fuel needle/seat.
I know it doesn't take much to stick that needle open.
You don't think this has anything to do with me changing the diameter of the fittings going from the fuel line to the carb? ( I had to increase it up to 1/2 inch to make the turn... but then reduced it back to 9/16 - 24 at the inlet.
Thanks for the tip.
The change in fuel line size shouldn't change the pressure at the needle. You also do not want to take the bowl off. Just loosen the lock and remove the needle/seat from the top of the bowl to inspect it.
I wouldn't want a piece of metal shaving bouncing around in my float bowl. I once found a fly in a main jet. Had to of come in through a vent tube when the air cleaner was off.
Originally Posted by KENS78SILVERANNIV
Turned out to be a stripped inlet so I ordered a new primary fuel bowl kit. In the meantime I rigged up a brass fitting into the old fuel bowl with about 1/8 inch more bite and a brass elbow with a fuel nipple to my fuel line.
It was after dark and I noticed a strange orange glow from under the hood about 2 miles out...
The fire department arrived quickly, but my poor old Monza was still .
It was a piece of junk anyway, but that car was a serious sleeper - not many people expected to have their doors blown off by a green MONZA!
Just a note of Thanks to all who suggested a stuck needle and seat.
I removed the secondary needle... blew it out with compressed air and after blowing out the bowl....reinstalled it and readjusted the float.
I also reset the gap for the accelerator pump for a litle more agressive blast of fuel into the primaries.
The carb runs like a champ... no smoke... no flooding.
Thanks guys!
By the way... Holley has an awesome tech site at their main website: www.holley.com
It's written in plain, easily understood English and the directions are simple and clear. Everything from trouble-shooting to tuning.
Thanks guys!
