Tansmission, rear survey
Old 08-15-2006, 07:39 AM
skyman51
skyman51's Avatar
Default Tansmission, rear survey
I am just curious. How many 66-67 427/390 cars do members have with the original combination of the M20 wide box and a 3.08 posi rear? My 67 was ordered that way and it is a pleasure to drive. It is like having a 3.36-3.55 in first gear and then able to cruise at highway speeds comfortably. It is the only way to go.
Old 08-15-2006, 08:09 AM
DZAUTO
DZAUTO's Avatar
Received 3,772 Likes on 1,674 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
That is the combo in my 56, but of course, that's not what came in it. I agree 100% that is the way to go today, ESPECIALLY if you drive the car out on the road as well as because of today's gas prices!!!
Old 08-15-2006, 12:37 PM
tentuna
tentuna's Avatar
3.36 and an M20 in a 327/350 great combo
Old 08-15-2006, 12:44 PM
magicv8
magicv8's Avatar
3.08:1 and wide (2.5:1 low gear) ratio - the way mine left the factory.
PS That's 7.7 turns of the engine per wheel rev
as opposed to 3.36:1 with 2.2 low gear for 7.4 revs.
The 3.08/2.5 combo put down more torque in low than the 3.36/2.2 combo that I am told was the default with HiPerf solid lifter cars. IMO that's why a lot of people with 3.36 gears say they don't want to go to 3.08s. They probably have the 2.2 low gear (providing less torque than a 3.08/2.5 combo switch would provide) and think the swap would mean less torque. Gotta do the math.
Old 08-15-2006, 01:16 PM
Allcoupedup
Allcoupedup's Avatar
I have the 3.36:1 rear end with the early M20 transmission and it is nice to drive. I think the ideal setup would be a 3.55:1 and an M20.
Brian
Old 08-15-2006, 09:40 PM
67L36Driver
67L36Driver's Avatar
Originally an L36 with 3.36 and close ratio (M21). Second gear starts are not a problem. Wish I had 3.08's.
Old 08-15-2006, 10:12 PM
Glenn's 67 BB Vert
Glenn's 67 BB Vert's Avatar
What would you think of a m22 with 391 ratio??--also the bb --just wondering -thanks-glenn
Old 08-16-2006, 12:21 AM
FastEddy
FastEddy's Avatar
Ran a 3:55 and 2.5(m20) for 75,000 miles and thought it was perfect. Blew rear and dropped in a 3:08 and it wasn't as bad as I thought - it was also good for seriously long burnouts
First gear launch with a 3:70 with a close ratio 2.2 is not too different than a 3:08 with wide ratio 2.5 = first gear final drive ratio 8.0 vs 7.7
a 3:55 with wide ratio (2.5)box is 8.9 I seem to remember the new vettes I think are @10.0 in first gear??...................
I always thought the close ratio box was designed for 3:70 gears and larger, and wide ratio box was for 3:55 and smaller (numerically).
Old 08-17-2006, 10:30 AM
magicv8
magicv8's Avatar
The way the racers looked at in the 60s, was: the Muncies with the 2.5 low were for road (racing) cars that mostly used high gear, while the ones with the 2.2 low were for dragstrip machines - because their fairly equal gear spacing allowed the engine to jump between gears from the end of the power curve plateau to the beginning of the plateau in the next gear - otherwise referred to as "staying on the cam".
Old 08-17-2006, 11:04 AM
MosportGreen66
MosportGreen66's Avatar
Our old L-79 Convertible had an M21 with 3:36 posi. You said it right. It is a Great Combo!
To Tansmission, rear survey
Quick Reply: Tansmission, rear survey
