Is 212 degrees the correct engine temp?
I checked the engine temp with my new ray gun. It reads 212 at the intake manifold and water pump. 160 approx at radiator. Is this correct temp for my small block motor? Has a 180 thermostat.
The correct place to "shoot" is the upper radiator hose forward of the thermostat housing. It's supposed to be 180 there and I wouldn't be surprised if it is.
A 180 degree themostat opens to allow flow at 180 degrees. That all. Engine temps can and do climb higher. 212 isn't unrealistic for a stopped car. I wouldn't worry about this much unless it rises while driving.
Compare the IR reading to your gauge and baseline the temp delta for future reference.
tc
tc
tc
tc
