C1 and C2 FAQ thread
#42
As the proud new owner of a magnificent all original 1962 Red on Red, Two Tops, 340hp w/ 4-spd I wish to thank you for the time spent putting this most excellent resource together!!
torinodude59 (11-13-2023)
#43
5th Gear
C2 Muncie Shifter gap tolerance bracket assembly.
I’m in the process of refurbishing my shift lever and bracket assembly.
After putting all the levers and reverse interlock back into the bracket (cage), I’m curious if there is an optimal tolerance for the gap left over after it’s assembled. I ask, because I haven’t any success on the web. Plenty for Hurst, but almost nothing for the stock unit. Maybe there isn’t a defined tolerance, but any advice is greatly appreciated.
