With everyones help on this forum, I believe I identified my gas leak as the filler neck gasket. I changed the gas cap (vented) and the filler neck gasket, I believe I got rid of the gas fumes in the garage, but now I have some back presure when I remove the gas cap. Is this normal. It makes sense to me because now the system is sealing where it was not prior. What do you think?
The replacement cap does have a small hole in the middle/inside and is identified as vented on the top. I'll blow and see if it vents, but maybe its defective because it definately had pressure buildup yesterday. Thanks for your comments.
