59 Wire Clip locations?
St. Jude Donor '06
Anybody with a 58-60 that can locate the wire clips holding the rear harness where it goes thru the flip lid area. My project has the holes filled.
Thanks,
Wayne
Thanks,
Wayne
There is a picture of the wire clip locations in the AIM, but there are no measurements. How accurately do you need them located? I'll go look at my '59 when I get a chance.
Charles
Charles
Here is the picture from the AIM and a picture of the area on my '59. Although my car has only one loop left, I would assume that the three wire loops were located at positions B,C, and D. The measurements between screw holes are in millimeters. The last measurement (75mm) is the distance from the center of the hole to the vertical piece of fiberglass at the door jamb.
Charles
Charles
