Can a vert handle the extra power?
Old 02-12-2007, 12:42 PM
Downdraft
Support Corvetteforum!
Downdraft's Avatar
Default Can a vert handle the extra power?
1965 Convertible 327/300
If I replace my 300 hp smallblock with a 600hp + 434 small block what else must be upgraded? I am in the process of installing a complete suspension kit (VBP) and have included adjustable strut rods.
I am running 235/70-15 on 8 inch rims (flaired fenders)
Can my stock U joints and rear end bracket handle the extra power - or will I start breaking things?
Would I be able to get the 600+ Hp to perform on the vert or should I go for a more "tame" 475-500 HP 383?
See the dyno sheet of the Steve Schmidt 434
434 cu. in. Pro "Street Series" Dyno Chart
RPM-----------------C TORQ---------------C PWR
BAND---------------FT - LB------------------CHP
4900------------------568.3--------------------535.5
5000------------------568.3--------------------541.1
5100------------------566.8--------------------550.3
5200------------------564.1--------------------558.5
5300------------------567.5--------------------572.7
5400------------------564.6--------------------580.5
5500------------------561.0--------------------587.5
5600------------------552.9--------------------589.5
5700------------------548.4--------------------595.2
5800------------------537.8--------------------594.0
5900------------------536.2--------------------602.4
6000------------------531.2--------------------606.8
6100------------------525.2--------------------610.0
6200------------------518.4--------------------612.0
6300------------------511.7--------------------613.8
6400------------------508.0--------------------619.0
6500------------------498.8--------------------617.3
6600------------------493.1--------------------619.7
6700------------------479.3--------------------611.4
MAX TORQUE------568.3
MAX HORSEPOWER------------------------619.7
Thanks.
Alex
Old 02-12-2007, 12:55 PM
ZYALTR
ZYALTR's Avatar
Alex, these drive trains have handled 400+ hp for a lot of years. That said ...if you throw 600hp and tourque at it on a regular basis be prepared for component failure. Things break.
Old 02-12-2007, 01:13 PM
66since71
66since71's Avatar
There may be some benefit in using big block yokes and companion flanges (they use caps instead of u-bolts) at either end of the half shafts. Also later C-3 drive shafts used larger U-joints and should (?) fit a C-2. Edit: That will require changing the input yoke to the rear end though. Finally the M-22 transmission has straighter cut gears to handle more torque.
Old 02-12-2007, 02:18 PM
MasterDave
Moderator
MasterDave's Avatar
Just keep the stock size tires and the only thing you will break will be traction.....
Old 02-12-2007, 03:21 PM
JohnZ
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
If you go with bigger tires without significantly upgrading the half-shafts, you'll get this eventually:
Old 02-12-2007, 05:28 PM
kenEDMUNDS
kenEDMUNDS's Avatar
Ouch!
Old 02-12-2007, 05:31 PM
67L36Driver
67L36Driver's Avatar
or a normal duty clutch. You got to have a weak link thats cheap to fix.
Old 02-12-2007, 06:16 PM
LouieM
LouieM's Avatar
Received 3,031 Likes on 1,250 Posts
My all-time favorite of JohnZ's many photos!
Old 02-12-2007, 09:05 PM
R6T7
R6T7's Avatar
Hey John -
How much horsepower was this car running?? Great pictures -
Bob
Old 02-12-2007, 10:01 PM
427Hotrod
427Hotrod's Avatar
Received 1,874 Likes on 912 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
They hold fine if the frame is solid. A little re-inforcing can't hurt either!!
JIM
Old 02-12-2007, 10:05 PM
mjmsc5
mjmsc5's Avatar
CI 2-3-4-5-6-7-8-9 Veteran
CI-4 Car Show Winner
CI-7 Car Show Winner
You would think you could get a couple of inches of clearance with the front tires. You just aren't trying hard enough
Old 02-12-2007, 10:32 PM
tdelph
tdelph's Avatar
Default upgrade
I have a convertible that can handle 600+ HP but you have to upgrade the rest of the drivetrain to handle it. A small block 600hp vette could be a little more uncivilized than a comparable BB...good luck
Old 02-12-2007, 11:40 PM
427Hotrod
427Hotrod's Avatar
Yeah,,,,,that was bad,,,,,he got some of the GOOD ones with big air showing but they were too fuzzy to use in magazine. I never could get him to let me have them!
But I'll try harder at the Cruise In this year!!
JIM
Old 02-13-2007, 02:01 PM
JohnZ
JohnZ's Avatar
Originally Posted by bobbeh
Hey John -
Bob
That was a 540 Merlin with 8" slicks. You can make a mess with stock tires too - note the twist in these half-shafts (Jerry Luck-built L-89 with stock tires), found just in time:
To Can a vert handle the extra power?
Quick Reply: Can a vert handle the extra power?
