66 brakes ?
Old 02-26-2007, 07:15 PM
Paintbug
Paintbug's Avatar
Default 66 brakes ?
Can any one tell where I can find casting number list? I need to know if the ones on the car I'm working on is original. The number on the front are 5473786. Haven't found the munber on the rear yet.
Old 02-26-2007, 10:42 PM
vark_wso
vark_wso's Avatar
Outer front caliper half should be 5473796. Perhaps you mistook the '9' for an '8'. (Inboard front s/b xxxx3795). Get an NCRS Tech Info & Judging Guide for such research. I think 4th edition is current for '66 model year.
Old 02-27-2007, 02:46 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
'65-'66-E67 1st-design caliper casting #s:
Front - 5465952 & 5465954
Rear - 5465902 & 5465905
Old 05-05-2007, 01:22 AM
spstack
spstack's Avatar
JohnZ,
You would happen to know the correct casting #'s for a 11/8/66 build date 67 327/300?
Best regards, Sean
Old 05-05-2007, 11:38 AM
JohnZ
JohnZ's Avatar
Not sure when in '67 the changeover happened from the 1st-design (guided-piston) calipers to the 2nd-design (non-guided piston) calipers, but the 2nd-design caliper casting numbers are:
Front: 5452273 & 5452270
Rear: 5452284 & 5452281
Most Chassis judges don't check the casting numbers anyway - hard to see anything up there lying on your back on the ground.
Old 05-05-2007, 05:40 PM
spstack
spstack's Avatar
Thanks... so to clarify, the Front inside 1/2 is 5452273 & outside 1/2 is 5452270? Rear inside 1/2 is 5452284 & outside 1/2 is 5452281?
Old 01-22-2013, 03:37 PM
petuniapilot
petuniapilot's Avatar
Default 65 Calipers
The casting # on the rear calipers for my 65 is 5465902. I can't find that casting number on Rockauto. That makes me worry that if I buy those new calipers from Rockauto, I'll be getting equipment that was originally designed for the 66 or 67. (I want everything on the car to be pristine original, whenever possible). Should I buy the 547xxxx casting series from Rockauto? Keep looking for my exact casting number, or try to clean the ones I have? How should I clean them?
Old 01-22-2013, 08:10 PM
JohnZ
JohnZ's Avatar
It's unlikely you'll find 1st-design caliper castings at Rock Auto, but the high-volume Corvette caliper rebuilders/suppliers have them and can match up a sleeved set for you. You need:
Front outers 5465952
Front inners 5465954
Rear outers 5465905
Rear inners 5465902
They will most likely have already had the internal piston guides machined out and have been built with the 2nd-design pistons, as the 1st-design pistons haven't been available for many years.
To 66 brakes ?
Quick Reply: 66 brakes ?
