grounding strap need a pic
Old 03-03-2007, 04:03 PM
justatoy
justatoy's Avatar
Default grounding strap need a pic
can anyone one put up a picture of the motor grounding strap and a picture of tha antenna grounding strap where it mounts to the antenna and frame thanks Bobby
Old 03-03-2007, 04:21 PM
67-427ci
Support Corvetteforum!
67-427ci's Avatar
This is what the antenna ground strap looks like. It attaches to the front side of the left rear body mount bracket. The engine ground straps are short, braided copper straps that attach to the motor mount mounting bolt (at the engine block) and then to the front side of the frame mounting bracket. There is another ground strap that goes from the #1 body mount bracket (in front of the driver) to the bird cage. And lastly there is a longer braided ground strap the goes from the accellerator arm to the intake manifold. That's all I have on my side pipe car. I am not sure if there are additional straps with under car exhaust.
Roy
Old 03-03-2007, 04:38 PM
62Jeff
62Jeff's Avatar
Default Here's the engine strap
This from my 65
Old 03-03-2007, 04:57 PM
justatoy
justatoy's Avatar
THANKS the one for the antenna do i need a 65 antenna is there a spot on it for the ground because i have a auto parts antenna and there is no where to connect the ground thanks
Old 03-03-2007, 04:59 PM
Trophy Blue
Trophy Blue's Avatar
How about this one.The strap goes from the bracket to a bolt with a star washer on the frame. The star washer goes first, then the strap and bolt.
Old 03-03-2007, 06:12 PM
DZVette
DZVette's Avatar
Here's the antenna ground strap mount to frame on my 65. Note that the star washer is incorrect here. Should be between the strap and the frame.
DZ
To grounding strap need a pic
Quick Reply: grounding strap need a pic
