Low Beam Headlight Out
Guest
Posts: n/a
The low beam headlight is out on the passenger side on my 66. I swithced the low beam bulbs to make sure it's not the bulb - no such luck - that would be too easy! The bulbs all work on the high beam setting.
My next guess is the wiring in the right headlight bucket - bubba was there at some point as a few of the wires are crimped and taped. Tonight I repaired these connections with new wire connectors, but the low beam bulb is still out.
Any ideas??? I'm thinking it may be time for new "Headlight bucket extension harnesses" from Lectric Limited. Thanks!
Tom
Tom
I would check that you have power to the right headlight, the contacts or socket could be bad. Also check ground while your there. The high beam is on another wire then low beam
Yes, agree with Driver 61. My low beam light went out on one side and still came on when switched to high beam. The think the low beam light may have 2 separate filiments in it - one for high and one for low. When I replaced the sealed beam unit, it worked both in high and low. I would try checking power and swapping left and right low beam sealed beam units to isolate the problem to the bulb or power.
This may sound a little silly but since Bubba was at work at some point...the low-beam connector on the passenger side is three-pin? The high-beam connector has only two pins. And yes, the sealed beam (low) has two filaments and just the low filament can burn out.
Three-pin low is on the right, high on the left.
You can just replace the sealed beam for under $10, unless....you want to put T-3 units in to keep the car correct. I was only able to find a complete set (that is how the vendor packages them) for around $125 I think. I still have the extra used low beam if you want to pay for me to ship it to you. I think it was in the car for over 10 years though. Like I said, if it was me, I would try swapping in the one from the other side to check.
Gregg
Tom
Tom
Guest
Posts: n/a
Thanks, guys!!!
I've tried switching the low beam bulbs side-to-side, but it's not the bulb. And even though bubba was there at some point, the connectors are correct (two and three prong connectors). It's sounds like it may be the high beam switch - I'll start there for now.
Tom
Tom
Received 1,858 Likes
It's not the dimmer switch. If you have a low-beam light on one side and not on the other side, it's in the wiring or connections forward of the dimmer switch - one wire from the dimmer switch serves the low-beam circuit on both sides. Get a test light and probe for power to find the open circuit.
