Spring Ring Hose Clamps...
Getting close to finishing the heater core installation and I came to where the heater hoses get attached to the heater core at the firewall. Won't have enough room to re-attach the clamps you tighten with a screwdriver (not the tower clamps, the other ones). So I'm going with the spring ring clamps, because they are a lot thinner and while I know they are correct in the first place, how is there holding power when tightened? It looks like when you tighten it over a rubber hose end, it would just bounce back from the rubber and not actually squeeze/tighten it.
Also, would it be a waste to get the spring ring hose clamp pliers? Or could you just take 2 pairs of pliers and pull outward to tighten them?
Thanks...
Thanks...
You'll hate yourself if you don't get those special pliers made for those clamps. Next to impossible and certainly frustrating to try to spread them without the special pliers.
If you have the opportunity, get extra clamps. They can break when they're squeezed open. If you don't wear eye protection, keep them away from your face.
They seem to hold just fine. Yeah, I too at first thought that they looked a little wimpy. But when you remove one a few years later, you'll see where it has left deep marks in the hose. Chevrolet built tens of millions of cars with these clamps, so I guess they work the way they're supposed to.
Received 1,857 Likes
Doc Rebuild has the best quality Corbin clamps - have used his for many years on several cars, and have never had a leaker. Definitely buy the Corbin clamp pliers with swiveling jaws - they make installation or removal quick and easy, without damaging the clamps.
Location: going faster miles an hour...with the radio on in browns mills new jersey
Being cheap, er I mean frugal, I made my own special tool by drilling the end of an old set of pliers. It works good enough for a tool I use very infrequently.
So they come pre-tightened...this is good news...
One of my drunken friends one day decided that he wanted to see how tight the spring rings are so, he put one on one of his fingers. All I heard was screaming since he could not get it off! Needless to say, he never did it again.
