63 SWC FI....questions on what is right and what is wrong
2019 Corvette of the Year Winner
St. Jude Donor '15
Found this on Ebay and have a twitchy bidding finger for it....what is right and what is wrong? Good deal or shy away? Anyone know this car?
http://cgi.ebay.com/ebaymotors/ws/eB...m=270120262158
there are more photos on EBay....let me know what you think....
Herb
Herb
Incorrect for a 63 -> Sidepipes, knock-off wheels, the female side of the hood latch should not have black paint on it.
Wrong -> Master Cylinder not 63, Four Speed linkage looks like 64 to 67.
Missing -> Radio side panel, Radio shielding on engine
Information needed -> What is the VIN derivative stamped on the engine pad and transmission?
The VIN tag looks like it is attached correctly as does the Trim Tag.
Not a bad car, I would hire some to crawl all over this to ensure it is a real Fuel Car.
I do not have a fuel car so I can't comment of the FI unit numbers
Harry
Harry
St. Jude Donor '15
Harry
Harry
Hey Firstgear
Hey Firstgear, this car is local for me. The guy I'm working with for my total nut and bolt off resto on my 67 is AMAZING. He's an NCRS Level 1 judge for 67. He specializes in 63-67 restoration, and has been doing it for years.
If you want, I can have Bob check this car THOROUGHLY for you. HIGHLY recommended.
PM me if you're interested. Bob was at my place this week and we pop riveted new #4 body mount brackets on my car.
Herb,
You've got to see it in person w/ someone who knows '63's. There are way too many expensive parts on '63's to buy from pictures. Here are some shots of my original unrestored SWC and my roadster.
http://ckautollc.photosite.com/63SplitWindowCoupe/
http://ckautollc.photosite.com/CarCo...leTanCorvette/
Noland's Vol.2 will help you as well. SWC's are very hot right now.
St. Jude Donor '15
Herb,
Received 1,843 Likes
You guys amaze me. Pickin' and pokin' at the wrong this, wrong that, not a '63 option. You look at the pissantes and let the elephants stampede right over you.
What about the poor front end fits of the headlight doors, hood and fender? That thing looks like it been glued back together by Ray Charles. Go find a good one.
St. Jude Donor '15
decided to pass on the car for the following reasons.....
1963 Red/Black SWC from Minnesota
Inspected by Bob Lund 5/20/07
Things that are correct
Frame has surface rust only, appears pretty solid
Birdcage is pretty good, slight surface rust only
Good door fit
Good headlight fit
Hood fit pretty good
Appears to have original brake lines
New shocks installed
Correct radio, but missing slider bump to switch between FM and AM
Correct casting number on block
Correct fuelie distributor
Correct steel S-tube for fuelie air intake
Correct 63 glove box door, slight crack
Optioned with Power Windows
Rear window trim all in place
Original rubber around vent windows
Original tail panel fiberglass section
Original dash pads
Good headliner, but missing lens for interior dome light
Things that are not correct, but in good condition
First body tab cut to install sidepipes
Sidepipes
Knock off wheels, they are reproductions
Wrong harmonic balancer (not the correct finned type for 63)
Replacement hood, not original
Someone undercoated the car at one point
Wrong master cylinder for 63
Hood hinges were shimmed to make the hood fit
Wrong voltage regulator
Wrong horn relay
Wrong alternator, also missing fan
Wrong gas line
Wrong valve covers (the ones installed have the famous casting flaw down the center of the O in Corvette, should be for late 66 and 67 only)
Wrong ballast resistor (part of ignition system, screwed to firewall
Weird fiberglass-like pieces glued or glassed onto the back side of the fender louvers
There are lock nuts on the back of the fender emblems (fuel injection)
Generic Corvette aluminum radiator, not correct for 63, but it works
Wrong screws on S-tube for fuelie air intake
1964 shifter
Wrong rear differential housing, couldnt (obviously) verify gears
Wrong radiator core support, this car has a 64 version
Wrong passenger side exhaust manifold, it is for a 365 horse car
Wrong radiator surge tank
Things that need fixing
Fiberglass patch in right front fender well, car has been hit most likely
Hand laid fiberglass in both rear wheel wells, we are speculating that the car had fender flares at one point
Paint is not show quality, but a good 10 footer
Driver side end cap of frame (near kickups) is rusted, has a slight hole, drain holes plugged
Oil leak from engine
Missing 1 horn
Seat covers and center console are in tough shape, theyre passable, but not very appealing to the eye
Cracked steering wheel
Loose steering wheel as it sits on the column
Loose drivers door arm rest
Pinched heater hose (just installed wrong)
No needle on temp gauge
Cluster was refurbished probably back in the 80s, with the wrong font of numbers for the odometer and trip odometer; correct ones now available
o Also, the red line looks a little too good, could probably have been a repaint; in other words, the cluster could have originally had a low red line, indicating that it was a small HP car, that had been converted to a fuelie
Car has been hit in RF corner
Unplugged parking light
Missing passenger side radio cover panel
Missing one coupe corner, that is a small metal piece right behind the passenger seat on the wall of the car that crimps the inner and outer trim pieces together (small part)
Slight fuse box rust, needs new wiring harness
No spare tire carrier
Tail wiring harness has been spliced, probably needs to be replaced
Needs new rear leaf spring
Hole in body for antenna has been filled in
Dent on passenger side vent window trim
Missing radio shielding
Missing ignition switch bezel
Dead battery
Good door fit
Good headlight fit
Original dash pads
Sidepipes
Wrong horn relay
Wrong gas line
1964 shifter
Missing 1 horn
Dead battery
St. Jude Donor '06
Appears to be a very thorough assesmment by Mr. Lund. A great example of why an inpsection by an expert is essential.
Yep, Bob and I had fun inspecting it though.
You gotta love it, when the guy who knows his stuff, sits in the driver's seat of the SWC, and the first words out of his mouth were "Well, the font on the numerals for the odometer and trip odometer are wrong."
Can you say "detailed knowledge"?
I am continually stunned by Bob's knowledge. I count my lucky stars that he's working on my 67. NCRS Top Flight, here I come.
i want to check my dampner bracket; what do you have to check to see if it is a fuelie car?
Seaside,
When Bob and I were there looking at the car, he said that a buzzer tach was installed on 63 fuelies (probably 64s and 65s too). Do you know if ALL fuelies had buzzer tachs?
Bob is currently doing a total frame off restoration on an original black/black 63 SWC fuelie (with the original motor). That car has a buzzer tach, this red car does not.
Seaside,
