BB Distributor and Valvetrain Oiling
Old 06-08-2007, 03:56 PM
mikem350
mikem350's Avatar
Default BB Distributor and Valvetrain Oiling
It was mentioned to me that there is a difference on the bottom of the BB dist shaft that forces more oil up top of the engine. Specifically, it can even quiet noisy lifters!! Also, owners have added the change using JB weld or something
Anybody have more info, specifically what years might be affected??
Thanks, Mike
Old 06-08-2007, 04:05 PM
427Hotrod
427Hotrod's Avatar
Received 1,873 Likes on 911 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
If there is, it will be news to me.
You can grind a slot to provide more oil to the cam/dist gear interface.
The '66 and older blocks needed a special groove in cam and bearing to provide oil to lifters.
But otherwise it's all the same stuff.
JIM
Old 06-08-2007, 04:49 PM
knight37128
knight37128's Avatar
This is an original big block distributor.
This is one that has been "modified".
If you do a search for "distributor", you will find the thread (not that long ago).
P.S. The pics were sent to me by members here (they are not my distributors).
Old 06-08-2007, 06:05 PM
GOSFAST
GOSFAST's Avatar
Default "Early" Factory Distributors
The info above is correct.
All the early years' distributors had to be installed in the "correct" position with respect to completing the oil system in both the SB's and the BB's. Back then if the vacuum advance location and the #1 spark plug wire was correct it "guaranteed" the oil system was set to go.
I'm not certain here, but I believe this was on the distributor's using the "cast-iron" housing's only!
If the "machined" groove, that was only 3/4's of the way around the housing, ended up in the wrong place, it actually became a restriction.
Thanks, Gary in N.Y.
P.S. Below here is a few photos of a '66 BB Vette, TI, restored unit with the "correct" housing.
Old 06-08-2007, 06:43 PM
427Hotrod
427Hotrod's Avatar
That makes sense...so that's a '65 and '66 distributor to go along with the rear cam bearing/grooved journal deal?
I gotta admit.....haven't messed with one of those in a long time!
jim
Old 06-08-2007, 07:19 PM
knight37128
Here is the original thread:
http://forums.corvetteforum.com/show...1594919&page=2
To BB Distributor and Valvetrain Oiling
Quick Reply: BB Distributor and Valvetrain Oiling
