White Wall Radials for a 64
Looking for White Wall Radials for my 64 Coupe. Many of the 205/75R15 tires that I looked at seem to be
1) A narrower White Wall that the 64 OEM Tires (I believe that the OEM tires were 1" White Walls), and
2) Seem to be "cheap", as in $50-60 price range. Not sure how good they will perform.
Are DiamondBacks or Coker speciality tires the only way to maintain the original look? Or, are there other ways to go.
I was looking at some Michelins, but they were only available in 205/70R15, and didn't know if they will fit.
Thanks.
P.S. Yes, my avatar needs to be updated to include the "Triplets"!!!!
Thanks.
I still have one of the original tires for my 64. It is a U S Royal Safety 800 whitewall. It has a 13/16" width. I'm running Goodyear Integrity tires, 205/70-15 that have a 23/32" whitewall. The same width whitewall is also on their 205/75-15 and their 225/70-15 tires. The Integrity has a slightly narrower thread width then some other brands, so they look a little more original, IMHO.
Location: Park City to SoCal - according to the map it's all down hill. No bad days in Indian Wells, California
I've got these Goodyear Regatta 2 on my 64 and get complemenst on them all the time. P215/70R15
Rich
P.S. Minus the wheel weights
Rich,
They really look nice. Do you know the actual width of the stripe. I tried the Goodyear Web site, and it was useless on specifications.
Ralph
Ralph
Received 1,857 Likes
Diamond Back will create any width whitewall (or redline, goldine, etc.) you want, any distance from the rim - just tell them what you need; they'll apply it to a current high-volume production radial tire that's round and will balance easily. Their Firestone Supreme 205/75-15 tire has a 1-1/4" wider tread than the same size Coker radial, and doesn't look "skinny".
www.dbtires.com
www.dbtires.com
see if they still make bf goodrich lifesaver radials.
i bought a set for my 64 vert maybe 6-7 years ago.
1 inch whitewall and a nice looking sidewall.
i can send you some photos if you like.
john
john
John,
Thanks for the advice. Based upon the Web-site BF Goodrich does not make these tires anymore. It appears that most of the U.S.-based tire companies are owned by either Michelin or Bridgstone.
Send an email to BF Goodrich to see if they have a replacement suggestion.
Ralph
Ralph
John,
Ralph
Ralph
here is a link to some of my photos,one showing the '64 with the 1 inch w-walls.
as i recall, i had to call or email bf goodrich and they got back to me that there was a tire i was looking for.
i ordered the tires from my local tire store. very reasonable.
if no luck try diamondback... i have them on my '66. bit more pricey but nice!
http://s225.photobucket.com/albums/d...ercorvetteguy/
Michelins With Whitewalls.............
I have a set on our 1966 Convertible and they are great tires. We have them mounted on the stock steel rims with 1966 hubcaps. No clearance issues that I am aware of. We have taken them on road trips of 200+ miles with no issues of any kind. In fact, our 1966 seems to run as well as our 1995 C4 Coupe which has much wider tires.
Interesting. Your safety 800 has a 7/8" wide whitewall and mine has a 13/16" wide whitewall. Mine was originally installed on my Oct 13, 1963 built 64. Most likely the difference is that they came out of different molds, even possible different mfg facilities produced them. Since the trend back then was to narrow the whitewall some each year, it's possible that your tire was produced earlier in 1963(or late 62) but they both were the same model of tire.
Guys,
Thanks for all your advice. Took Rich's lead and ended up with the Goodyear Regatta 2s. Nice look, affordable, and the local tire dealer had them within 2 days.
