C1 Dual Quad Problem
My original carter carbs have just about had it - car sputters, burns rich and reaks of fuel. I want to drive the car soon without having to do lengthy rebuild waiting on kits or sending to a service, etc.; so I tried replacing them w/a pair of edelbrock 1404's - but the butterfly's on the bottom are too big for the openings on the stock intake. Does anyone know of a bolt on carb replacement or a way to make the edelbrock's fit (yes, I am keeping the original carbs for the car - but I have had great luck with edelbrock on other cars). I just want to get a low-maintenance set of carbs keeping the original dual quad intake on the car. Any and all ideas/suggestions are greatly appreciated.
Thanks a bunch,
Joe
Thanks a bunch,
Joe
Received 1,843 Likes
Try JC Whitney Auto in Chicago or a similar place. They used to make adaptors for AFB to WCFB mounting.
They'll be on the top shelf, back row with lots of dust on them if you can find them.
http://www.speedwaymotors.com/p/70,5...itemNo=7202085
but haven't personally confirmed it. My WCFB's are killing me too -- they soak my plugs with soot until the car misfires - shipped both carbs off for a rebuild after fighting with them for weeks. I have a rebuilt single Carter and manifold for a '61 vette I'm considering using in the meantime.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
That is exactly correct! About 40+yrs ago, this was a fairly common way to install AFBs on the original WCFB manifold. You may have to do some searching, but I bet you can find a pair of the adapters.
Also, the WCFB is really a fairly good carb and quite simple (as 4bl carbs go). They're worth saving/rebuilding-----------------ESPECIALLY if they are matched 2x4 carbs!!!!
I read on another forum that this works:
Thanks a bunch
This thread got me to thinkin' about a way to improve the fuel distribution of the 2 x 4 setup. By design, having the engine run off of the rear carb only promotes rich rear cylinders and lean front cylinders. I suppose that is why the rear spark plugs soot up and cause problems. However, I am curious if anyone has ever installed leaner primary jets and rods in the primaries of BOTH the front and rear carbs so that the engine runs off of both carbs front 2-BBls. This can be accomplished with a linkage change to the upper hole on the front carb. I have modified standard Edelbrock metering rods to form a loop on the top that mimics the original WCFB rods. It is easy to do with a couple of pair of needle-nose pliers and patience. I believe standard Edelbrock or Carter main jets will fit the WCFB holes. Through trial and error, it seems to me that this could be the answer to the problems many are having with the 2 x 4 setup. Any thoughts?
Think that GM (and all the other guys) knew what they were doing when they used progressive linkage.
Note that this was with dual 500 CFM Carter carbs on an Offenhauser manifold.
Plasticman
