Crank shaft pulley info needed
A friend has a C2 with no power steering or AC - just an alternator. He noticed a wobble in the crankshaft pulley and removed it. It appears that Bubba used a flat one grove pulley with 5 washers between the pulley and the balancer to put the belt in the same plane as the water pump and the alternator.
We need to get rid of the washers and replace the flat pulley with a correct pulley.
Anyone know what the correct pulley part number or application is? Can a generic pulley from Jegs do the trick and if so what should the application be?
Received 1,857 Likes
The pulley is for a small block.
John - thanks for the info on generic application part.
Unfortunately... this actually happened to me this year... and, at Hot August Nights...
Went around to the car parts stores, and engine builders in the area, who laughed when they saw the bubba'd pully... (was a dual split, cant believe I missed it) no one had a single harmonic balancer pulley, somewhat rare.
Turned out that Summit Racing had a shiny chrome one... it mostly fits, good enough to get through the show. I need to find the proper one this winter.
Cj
Cj
