rams horn clear angle plug heads?
Maybe a dumb question here, but will angle plug heads work (clear) with rams horns exhaust manifolds? I tried searching the forum but didn't see any definitive answers.
should be no problem... i believe the plugs angle toward each other... meaning.... plugs 1 and 3 angle toward each other, and plugs 5 and 7 angle toward each other.
This should give plenty of clearance.
i'd definatly take a manifold with me to mock up though before purchase.
Aaron
Aaron
Yep, they work OK.
Here is a ZZ4 with the L98 heads and 2 1/2 inch ram horns
blackmagic......
Thanks for the confirm. I'm curious as to whether you'd considered running headers with your set-up. I actually took off a real nice set of hooker headers that were on my '61 when I bought it (I wanted to go with a stock look), but I've been second guessing myself sometimes about what I might be loosing by not having left the headers on.
rams horns and angle plug heads
I just installed a pair of 2 1/2 inch rams horns on my new crate motor with fast burn heads. The angle plugs work better than the straight ones. I port matched the manifolds to the heads. Worked out well.
Dave
Dave
