1966 circuit breaker- right way, wrong way ??
when hooking up a circuit breaker for the power windows/headlight buckets, is there a correct way of doing this? the reason i ask is that both the wires are RED but the terminals on the new circuit breaker are different lengths. thanks for the info. pusher
Received 1,857 Likes
Makes no difference which way it's connected.
thanks john. well, that answers my thoughts on whether these circuit breakers were original or not. they ARE identical and were made by LITTELFUSE INC, DESPLAINES, USA. i imagine they were replaced at the same time. anyone have any idea the life span of these litte suckers? these look pretty old and i know the lady that owned the car before me, stopped driving it about 1995. pusher
I had the same question last week when I was installing the new main harness. On the face plate one side is marked "Aux" and the other side "Bat." I used the multimeter and checked the wires to match the "aux" side to the lead going to the headlight motor switch. The other side goes out through the right bulkhead connector into the main engine harness and ultimately to the battery.
However, as John stated it really should make no difference since the purpose of the CB is to connect these two feeds until such a time as something goes wrong. In which case it should work regardless of orientation of the two wires.
