Shark Bite rear coil-over and Steeroids GP
Premium Supporting Vendor
We have had some interest in a group purchase for the new Shark Bite rear coil-over kit. Additionally, we have had interest in a Steeroids GP so we decided to combine the two. We would like to see at least 6 willing to participate in order to launch this. Please post up and I’ll add you to the list.
Here are the details.
Free shipping for all GP orders
Shark Bite Coil-overs
Coil-over information
- $1619.10 for double adjustables – saves $179.90
- $1349.10 for single adjustables – saves $149.90
Steeroids
Steeroids information
- $1127.28 – saves $153.72
Purchase a Steeroids and a Coil-over kit together and save more
- Steeroids $1088.85 – saves $192.15 on Steeroids for a total savings of
• $372.05 for double adjust and Steeroids (total price of $2707.95)
• $342.02 for single adjust and Steeroids (total price of $2437.95)
On the list for the GP:
1. jimvette999
2. belmara
3. Snowman
4. pletner
5. Tom Westbrook
6. maddmickey
7. OldCorvetteKid
8. flips66
Steeroids
1. jimvette999
2. belmara
3. Snowman
4. pletner
5. Tom Westbrook
6. maddmickey
7. OldCorvetteKid
8. flips66
__________________
www.SpeedDirect.com
Corvette Forum Members get 10% off with code: CF10
Steeroids rack & pinion conversion kit for '53-'82 Corvettes
Shark Bite Suspension Front & Rear Coil-Overs, Aluminum A-Arms & Diff Covers, Stage Kits
Rod Links Spherical rod end clutch linkage for '65-'82 Corvettes
www.SpeedDirect.com
With the new participants added we can officially begin the GP. So we are now open for orders. You can order this week by calling 1-866-338-1545. If anyone else wants to join this group purchase, feel free to do so. Just post here that you would like to and I'll add you to the list.
Cesar911 (05-31-2021)
There are several advantages. BuffaloBILL hit one of them. Our kit allows for wider wheels to be run without interference from the spring. If you have offset trailing arms you can still run a wider wheel and tire with this design because the spring will not be in the way. This is especially true for 15" wheels but any wide tire will have issues with the stock spring. Additionally some advantages are 1. truly independent rear suspension by having 1 spring for each wheel 2. coil-over springs and shocks have greater adjustability and ease for ride height changes 3. springs can be changed quickly 4. adjustable shocks make for an optimized ride (to your tastes) and, yes, 5. the coolness factor.
6th Gear
Flips66
I already purchased your front tubular upper A-arms and double adjustable coil overs. I'm in on the GP for the rear double adjustable coil overs also. Now, when do the lower tubular A-arms come out? And then the C5/C6 brake upgrade???
I added you to the list, welcome. We are working on the lower control arms and the brakes. We hope to have more information soon.
6th Gear
Can't Wait
If I also spring for the steeroids, does it count as another "participant"? Do you also sell the power steering pump and brackets? I'm ready so just let me know when you are good to go.
I assume this will work on C2. Are there any hard numbers to prove this is better then the composite mono spring, and autocross Bilsteins? Skidpad and lateral G data would be nice. Thanks.
Regards,
Gerry
Regards,
Gerry
Yes, this fits a C2. We don't have any back-to-back comparisons with the stock suspension. Besides, I suspect that skidpad numbers wouldn't be much different. The difference will be noticed more in a dynamic environment such as on the track with bumps and curbs as well as the tuneability of the shocks and the ease of changing springs. We have plans for some skidpad testing in the next few months but it is more for front suspension than the rear. Never the less we will have some data at that time. Please let me know if you have any further questions.
