1966 327/350hp Water Pump... Date Stamped?
Received 1,857 Likes
No such thing as a water pump to "match" a block; all that matters is that the water pump casting date must be prior to the engine assembly date stamped on the pad, if that matters to you. Water pump casting dates aren't judged, as they can't be seen with the pulley installed.
