What carter wcfb was on my 1960?
Old 05-25-2008, 07:58 AM
HDVETTE
HDVETTE's Avatar
Default What carter wcfb was on my 1960?
I have the oringinal block for my 1960 and it is date stamped Feb 9, 1960. What carter carb model would have been on it 2818S or 3059S? It is a 283 1x. The only clue to manufacturer date is the engine stamp of feb 9 1960 and the vin last five are 04607 if that helps.
Old 05-25-2008, 04:02 PM
provette67
provette67's Avatar
when was it built?
Old 05-25-2008, 04:52 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
It would help if we had a clue about which engine it is - 1x4?, 2x4 245hp?, 2x4 270hp?
Old 05-25-2008, 08:03 PM
HDVETTE
HDVETTE's Avatar
Originally Posted by provette67
when was it built?
Even though the feb engine date? The NCRS manual says 59 and early 60 is 2818S.
Thank you
Old 05-25-2008, 09:44 PM
1snake
1snake's Avatar
Definately a 3059S is the correct one for that car.
Jim
Old 05-26-2008, 09:16 AM
provette67
provette67's Avatar
both the 2818 and the 3059 use the same carb top #1396.The center section for the 2818 is #208 or 1208.The center section for the 3059 is #1353 or 1517.But you definetly need the 3059
To What carter wcfb was on my 1960?
Quick Reply: What carter wcfb was on my 1960?
