radiator removal on 60 vette
4th Gear
First I must admit that I am not mechanically inclined. I have searched the archives and haven't found an answer to this problem. I need some advice on the removal steps for this leaky radiator that needs to be removed from my 1960 roadster. I have removed the 4 bolts/screws that fasten the top of the radiator to the radiator supports. And I have removed the 4 screws that fasten the shroud to its supports. Now, that altho the radiator is willing to slide up and out, the lower hose outlet hangs up on the shroud. So if the shroud must come out, it appears that I need to remove an arm that is held in place by two bushings and passes thru the center of the shroud for the radiator removal process to continue. Is this OK or is there away around this?
remove the shrouding
4th Gear
fan too?
Thanks for the quick replies. I am assuming then without going out to the shop and looking that the arm that goes through the shroud does not have to come out since the shroud is in 3 parts. Also, do I need to take the fan off to accomplish this task?
You don't have too, but it might make it easier on you.
Also if you fill out your location you might find someone close to stop and help. Usually only costs a couple beers.
I took mine out so I wouldn't damage cooling fins in radiator. Mark the front or rear of fan to indicate front or rear so you don't put fan back in incorrectly.
